Bus 003 Device 004: ID 0402:0402 ALi Corp.diese Zeile taucht auf, wenn das usb interface angesteckt ist.
Sonst nix!
Gruß Markus
Bus 003 Device 004: ID 0402:0402 ALi Corp.Code: Select all
rwxr-xr-x 2 root root 140 2009-08-08 08:56 by-id
drwxr-xr-x 2 root root 160 2009-08-08 08:56 by-path
crwxrwxrwx 1 root root 13, 64 2009-08-08 10:56 event0
crwxrwxrwx 1 root root 13, 65 2009-08-08 10:56 event1
crwxrwxrwx+ 1 root root 13, 66 2009-08-08 10:56 event2
crwxrwxrwx+ 1 root root 13, 67 2009-08-08 08:56 event3
crwxrwxrwx 1 root root 13, 68 2009-08-08 08:56 event4
crwxrwxrwx 1 root root 13, 69 2009-08-08 08:56 event5
crwxrwxrwx+ 1 root root 13, 70 2009-08-08 08:56 event6
crw-r----- 1 root root 13, 63 2009-08-08 10:56 mice
crw-r----- 1 root root 13, 32 2009-08-08 10:56 mouse0
crw-r----- 1 root root 13, 33 2009-08-08 08:56 mouse1
crw-r----- 1 root root 13, 34 2009-08-08 08:56 mouse2Code: Select all
Set new path for the resources: /home/markus/heli/HELI-X/resources/
Set new path for the user files: /home/markus/heli/HELI-X/files/
Using openGLLayer JOGL_AWT
Found 59 display modes
Linux plugin claims to have found 6 controllers
No Joystick foundCode: Select all
Aug 8 09:02:34 polarstation kernel: [ 373.148012] usb 6-1: new low speed USB device using uhci_hcd and address 2
Aug 8 09:02:34 polarstation kernel: [ 373.303307] usb 6-1: configuration #1 chosen from 1 choice
Aug 8 09:02:34 polarstation kernel: [ 373.341075] input: HID 0402:0402 as /devices/pci0000:00/0000:00:1d.0/usb6/6-1/6-1:1.0/input/input7
Aug 8 09:02:34 polarstation kernel: [ 373.344989] generic-usb 0003:0402:0402.0004: input,hidraw3: USB HID v1.00 Joystick [HID 0402:0402] on usb-0000:00:1d.0-1/input0
Aug 8 09:04:46 polarstation kernel: [ 505.592227] usb 6-1: USB disconnect, address 2Code: Select all
drwxr-xr-x 2 root root 180 2009-08-08 14:01 by-id
drwxr-xr-x 2 root root 200 2009-08-08 14:01 by-path
crwxrwxrwx 1 root root 13, 71 2009-08-08 14:01 event7
crw-r--r-- 1 root root 13, 0 2009-08-08 14:01 js0
Aug 8 13:57:51 polarstation kernel: [ 2191.984009] usb 3-1: new low speed USB device using uhci_hcd and address 2
Aug 8 13:57:51 polarstation kernel: [ 2192.138306] usb 3-1: configuration #1 chosen from 1 choice
Aug 8 13:57:51 polarstation kernel: [ 2192.158077] input: HID 0402:0402 as /devices/pci0000:00/0000:00:1a.0/usb3/3-1/3-1:1.0/input/input8
Aug 8 13:57:51 polarstation kernel: [ 2192.164668] generic-usb 0003:0402:0402.0005: input,hidraw3: USB HID v1.00 Joystick [HID 0402:0402] on usb-0000:00:1a.0-1/input0
Aug 8 14:01:05 polarstation kernel: [ 2385.680050] usb 3-1: USB disconnect, address 2
Aug 8 14:01:14 polarstation pulseaudio[6379]: pid.c: Stale PID file, overwriting.
Aug 8 14:01:58 polarstation kernel: [ 2439.440013] usb 3-1: new low speed USB device using uhci_hcd and address 3
Aug 8 14:01:58 polarstation kernel: [ 2439.594292] usb 3-1: configuration #1 chosen from 1 choice
Aug 8 14:01:58 polarstation kernel: [ 2439.626078] input: HID 0402:0402 as /devices/pci0000:00/0000:00:1a.0/usb3/3-1/3-1:1.0/input/input9
Aug 8 14:01:58 polarstation kernel: [ 2439.632357] generic-usb 0003:0402:0402.0006: input,hidraw3: USB HID v1.00 Joystick [HID 0402:0402] on usb-0000:00:1a.0-1/input0
No Joystick found
