My USB interface, and associated configuration, is good -- yet when I start Heli-X, no data appears from the USB device.
To fix this, I don't actually do anything!!
I just quit and try again, several times. Sometimes I unplug the DX7 while Heli-X is starting then plug it in after the field appears.
Note: Heli-X does NOT say "no controller detected" unless I unplug the USB stick.
Everything almost seems like it should work but in controller config, bars are centered and no buttons can be tripped.
As I said, this happens when starting, but not after multiple attempts to restart, then suddenly - everything is ok!!
this USB controller / DX7 combination has been free of problems and used on windows without issue. And when Heli-X starts to see data, it works for as long as you want. Including un-plugging and plugging in the DX7 again.
It just seems to have a problem 4 times out of 5 during init.
bug? - controller rarely fully recognized from start
Re: bug? - controller rarely fully recognized from start
Strange.
Do you see an error message in the comsole window?
No errors in console.
It starts, does not complain there is no controller connected, but no inputs change -- either X-Y or buttons.
so then I unplug USB, then re-plug, and re-start Heli-X, maybe a few times, then suddenly all is good.
