Issues with Heli-X launching in OSx 10.8.2
jbudowski
Post by jbudowski »
Application will no longer launch. Shows up on dock then disappears. Console shows com.apple.launchd.peruser.501: ([0x0-0x4f04f].net.heli-x.heli-x[642]) Exited with code: 1. Using Java 7 update 13. Thanks.
Re: Issues with Heli-X launching in OSx 10.8.2
Please download the latest Java 6 from Apple's website.
http://support.apple.com/kb/DL1573
jbudowski
Post by jbudowski »
That package will only load with OSx 10.6. I'm running 10.8.2. Thanks.
Sorry, this should work:
http://support.apple.com/kb/DL1572
jbudowski
Post by jbudowski »
Successfully installed the specified version of Java but, unfortunately, same result, same error.
Then you can try to remove Java 7.
michael
ssalmenkivi
Post by ssalmenkivi »
I have a similar problem with OSx 10.8.2 - I just downloaded Heli-X 4.2 but the dmg file doesn't start.
I have Java 1.6.0_41.
what exactly is going on? Could you unzip the file? Could you open the dmg file? Could you install the app?
michael
jbudowski
Post by jbudowski »
So I finally figured out the issue. My antivirus software was blocking some of the files. Figuring that out was only half the problem! Then I had to figure out how to make it stop (which should have been much easier than it turned out to be). Anyway, I'm in good shape now. Thanks.
