You may update to Rev 2443. New
Key assignable to a switch color (1-10) function which can change all, colors, textures and materials...
The language files are adapted accordingly.
Have fun and thank you for the feedback.
Rev 2443
Re: Rev 2443
maybe not specific to this version, but after getting a 4k monitor and changing the resolution settings (to 3840x2160) and the font size (to 32 (4k)) I see 2 problems:
* sometimes in full screen mode the mouse pointer is not visible (independent of the setting 'hide mouse pointer')
* the 'show sticks' HUD moved out of the visible screen. There seems to be no way to bring it back.
Regards
Regards
Re: Rev 2443
Are you on Windows or MAC OSX?
Please try "factory settings" in the simulation menu.
Re: Rev 2443
the timer (HUD => show timer) consumes 50 fps in my case
. Please see the following video: https://file.io/O9i0hz9DrFqs
Regards
Regards
Re: Rev 2443
ok, the timer is updated in 2444 ...
modellermark2
Re: Rev 2443
There is a Java update available - Version 8 Update 311 - is it OK to update to that or will it affect Heli-X?
Thanks, Mark
Thanks, Mark
Re: Rev 2443
Hi, V10 comes with Java 11, V9 with Java 8. On which operating system are you?modellermark2 wrote: ↑15 Nov 2021 07:55 There is a Java update available - Version 8 Update 311 - is it OK to update to that or will it affect Heli-X?
Thanks, Mark
modellermark2
Re: Rev 2443
I am on Windows 10 Pro all up to date and have Heli-X 10 installed - odd that I should be on Java 8 then although I do have one other piece of software that uses Java.
Has it been tested on Windows 11 as I have that available as an update too?
