Heli-x running slow after activation
Re: Heli-x running slow after activation
@PeterM: under XP there are two possibilities to reduce colour depth: in the graphics properties, and in the 3D page of the driver settings (3D color depth can be set independently from the desktop color depth). I used the Intel driver' internal OpenGL setting to prevent the desktop from using reduced colours, so I didn't need the XP-provided color settings. Does your driver not have any option page for tweaking 3D? Cannot test under Windows 8 so I don't know if under Windows 8 the driver looks different. Intel drivers under XP usually look nearly the same even with different chipset versions
PeterM
Post by PeterM »
Michael,
Yes dump of the batch file output below.
C:\HELI-X4>set system=windows-i586
C:\HELI-X4>set libPath=./libs
C:\HELI-X4>set libPath=./libs;./libs/gluegen/windows-i586
C:\HELI-X4>set libPath=./libs;./libs/gluegen/windows-i586;./libs/jinput/windows-
i586
i586;./libs/jogl/windows-i586
i586;./libs/jogl/windows-i586;./libs/lwjgl/windows-i586
i586;./libs/jogl/windows-i586;./libs/lwjgl/windows-i586;./libs/joal/windows-i586
C:\HELI-X4>set jars=./libs/HeliX/HeliX.jar
C:\HELI-X4>set jars=./libs/HeliX/HeliX.jar;./libs/gluegen/gluegen-rt.jar
C:\HELI-X4>set jars=./libs/HeliX/HeliX.jar;./libs/gluegen/gluegen-rt.jar;./libs/
jagatoo/jagatoo.jar
jagatoo/jagatoo.jar;./libs/javagamenetworking/jgn.jar
jagatoo/jagatoo.jar;./libs/javagamenetworking/jgn.jar;./libs/jdom/jdom.jar
jagatoo/jagatoo.jar;./libs/javagamenetworking/jgn.jar;./libs/jdom/jdom.jar;./lib
s/joal/joal.jar
s/joal/joal.jar;./libs/jogl/jogl.jar
s/joal/joal.jar;./libs/jogl/jogl.jar;./libs/lwjgl/lwjgl.jar
s/joal/joal.jar;./libs/jogl/jogl.jar;./libs/lwjgl/lwjgl.jar;./libs/jinput/Jinput
.jar
.jar;./libs/math/openmali.jar
.jar;./libs/math/openmali.jar;./libs/xith/xith3d.jar
.jar;./libs/math/openmali.jar;./libs/xith/xith3d.jar;./libs/xith/hud-themes.jar
.jar;./libs/math/openmali.jar;./libs/xith/xith3d.jar;./libs/xith/hud-themes.jar;
./libs/sound/jogg-0.0.7.jar
./libs/sound/jogg-0.0.7.jar;./libs/sound/jorbis-0.0.15.jar
./libs/sound/jogg-0.0.7.jar;./libs/sound/jorbis-0.0.15.jar;./libs/sound/tritonus
_share.jar
C:\HELI-X4>Java\jre7\bin\java.exe -Dsun.java2d.noddraw=true -Djava.library.path=
./libs;./libs/gluegen/windows-i586;./libs/jinput/windows-i586;./libs/jogl/window
s-i586;./libs/lwjgl/windows-i586;./libs/joal/windows-i586 -Xmx512m -XX:+UseConcM
arkSweepGC -classpath ./libs/HeliX/HeliX.jar;./libs/gluegen/gluegen-rt.jar;./lib
s/jagatoo/jagatoo.jar;./libs/javagamenetworking/jgn.jar;./libs/jdom/jdom.jar;./l
ibs/joal/joal.jar;./libs/jogl/jogl.jar;./libs/lwjgl/lwjgl.jar;./libs/jinput/Jinp
ut.jar;./libs/math/openmali.jar;./libs/xith/xith3d.jar;./libs/xith/hud-themes.ja
r;./libs/sound/jogg-0.0.7.jar;./libs/sound/jorbis-0.0.15.jar;./libs/sound/triton
us_share.jar HELIX
Set new path for the resources: C:/HELI-X4/resources/
Set new path for the user files: C:/HELI-X4/files/
Found 57 display modes
Dec 09, 2012 11:07:28 AM net.java.games.input.DefaultControllerEnvironment getCo
ntrollers
WARNING: Found unknown Windows version: Windows 8
ntrollers
WARNING: Attempting to use default windows plug-in.
Controller found: Name: SAILI Simulator --- XTR5.5+G2+FMS Controller(SAILI Simul
ator --- XTR5.5+G2+FMS Controller)
Using Stick SAILI Simulator --- XTR5.5+G2+FMS Controller
Analog component found:Slider
Analog component found:Z Rotation
Analog component found:Y Axis
Analog component found:X Axis
Digital component found:Button 3
Controller configuration file found: C:/HELI-X4/files/controller/SAILISimulator-
--XTR55G2FMSController.xml
Controller configuration file C:/HELI-X4/files/controller/SAILISimulator---XTR55
G2FMSController.xml read
javax.media.opengl.GLException: javax.media.opengl.GLException: Method "glActive
Texture" not available
at javax.media.opengl.Threading.invokeOnOpenGLThread(Threading.java:271)
at javax.media.opengl.GLCanvas.maybeDoSingleThreadedWorkaround(GLCanvas.
java:410)
at javax.media.opengl.GLCanvas.display(GLCanvas.java:244)
at org.xith3d.render.jsr231.CanvasPeerImplAWT.initRenderingImpl(CanvasPe
erImplAWT.java:735)
at org.xith3d.render.DefaultRenderer.doRender(DefaultRenderer.java:524)
at org.xith3d.render.DefaultRenderer.renderOnceInternal(DefaultRenderer.
java:686)
at org.xith3d.render.DefaultRenderer.renderOnce(DefaultRenderer.java:819
at org.xith3d.base.Xith3DEnvironment.render(Xith3DEnvironment.java:500)
at org.xith3d.loop.RenderLoop.renderNextFrame(RenderLoop.java:619)
at org.xith3d.loop.RenderLoop.loopIteration(RenderLoop.java:642)
at org.xith3d.loop.RenderLoop.update(RenderLoop.java:698)
at org.xith3d.loop.UpdatingThread.nextIteration(UpdatingThread.java:487)
at org.xith3d.loop.RenderLoop.nextIteration(RenderLoop.java:709)
at org.xith3d.loop.RenderLoop.loop(RenderLoop.java:762)
at org.xith3d.loop.UpdatingThread.run(UpdatingThread.java:540)
at org.xith3d.loop.RenderLoop.run(RenderLoop.java:785)
Caused by: javax.media.opengl.GLException: Method "glActiveTexture" not availabl
e
at com.sun.opengl.impl.GLImpl.glActiveTexture(GLImpl.java:33)
at org.xith3d.render.jsr231.TextureUnitStateUnitPeer.selectServerTexture
Unit(TextureUnitStateUnitPeer.java:161)
at org.xith3d.render.jsr231.OpenGLStatesCacheImpl.update(OpenGLStatesCac
heImpl.java:77)
at org.xith3d.render.jsr231.CanvasPeerImplBase.init(CanvasPeerImplBase.j
ava:126)
at org.xith3d.render.jsr231.CanvasPeerImplAWT.init(CanvasPeerImplAWT.jav
a:324)
at com.sun.opengl.impl.GLDrawableHelper.init(GLDrawableHelper.java:72)
at javax.media.opengl.GLCanvas$InitAction.run(GLCanvas.java:418)
at com.sun.opengl.impl.GLDrawableHelper.invokeGL(GLDrawableHelper.java:1
89)
at javax.media.opengl.GLCanvas$DisplayOnEventDispatchThreadAction.run(GL
Canvas.java:452)
at java.awt.EventQueue.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$200(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(Unknown Sour
ce)
Exception in thread "Xith3D render thread" javax.media.opengl.GLException: javax
.media.opengl.GLException: Method "glActiveTexture" not available
java:410)
at org.xith3d.render.jsr231.CanvasPeerImplAWT.destroy(CanvasPeerImplAWT.
java:791)
at org.xith3d.base.Xith3DEnvironment.destroy(Xith3DEnvironment.java:546)
at org.xith3d.loop.RenderLoop.destroy(RenderLoop.java:414)
at org.xith3d.loop.InputAdapterRenderLoop.destroy(InputAdapterRenderLoop
.java:211)
at org.xith3d.loop.RenderLoop.destroyAndExit(RenderLoop.java:446)
at org.xith3d.loop.RenderLoop.run(RenderLoop.java:806)
e
heImpl.java:77)
ava:126)
a:324)
89)
Canvas.java:452)
ce)
der Grafikkartenbtreier muss aktualisiert werden (am besten von der Herstellerseite des Grafikkartenherstellers).
