Belt CP V2 als Model fast fertig
Klinki
Re: Belt CP V2 als Model fast fertig
Post by Klinki »
ZeXx86 wrote:It is perfect, thank you very much !
Last thing for future, there should be little different heli sound; But over it is excelent work
Tanks ! I`m not so happy in Heli-x V2.0 with the sound either. He is fundamentally better in V3.0.
I don't know why it is, the same sound file. Ask Michael.
the differences regarding sound are:
1. In 2.0 you have two sound file for each heli (engine and blade sound depending on stall), whereas in 3.0 there is a further sound for the tailrotor. It is dependend on the load of the tail rotor.
2. I found out that the implementation of the doppler effect is different with different drivers. You have the possibility in 3.0 to adjust the doppler factor more easily in the configuration menu.
