No controller found
vanessa
No controller found
Post by vanessa »
HELI-X ver 4.1
OS Debian GNU/Linux wheezy
$ ls -l /dev/input/js*
crw-rw-rwT 1 root root 13, 0 oct 13 22:21 /dev/input/js0
jstest works and displays the sticks position
run heli-x
./runHELI-X.sh
Set new path for the resources: /home/vanessa/HELI-X41/resources/
Set new path for the user files: /home/vanessa/HELI-X41/files/
Found 4 display modes
        at net.java.games.input.LinuxEnvironmentPlugin.enumerateJoystickControllers(LinuxEnvironmentPlugin.java:408)
        at net.java.games.input.LinuxEnvironmentPlugin.enumerateControllers(LinuxEnvironmentPlugin.java:235)
        at net.java.games.input.LinuxEnvironmentPlugin.<init>(LinuxEnvironmentPlugin.java:115)
        at java.lang.reflect.Constructor.newInstance(Constructor.java:532)
        at java.lang.Class.newInstance0(Class.java:372)
        at java.lang.Class.newInstance(Class.java:325)
        at net.java.games.input.DefaultControllerEnvironment.getControllers(DefaultControllerEnvironment.java:160)
        at a.a.a.n.a.q(Unknown Source)
        at a.a.a.n.a.<init>(Unknown Source)
        at a.a.a.g.h.U(Unknown Source)
        at a.a.a.g.h.<init>(Unknown Source)
        at a.a.a.m.q.<init>(Unknown Source)
        at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:226)
        at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:670)
        at java.awt.EventQueue.access$400(EventQueue.java:96)
        at java.awt.EventQueue$2.run(EventQueue.java:631)
        at java.awt.EventQueue$2.run(EventQueue.java:629)
        at java.security.AccessControlContext$1.doIntersectionPrivilege(AccessControlContext.java:105)
        at java.awt.EventQueue.dispatchEvent(EventQueue.java:640)
No Joystick found
and I see a pop-up window "No controller found"
How to fix it ?
Re: No controller found
this Execption is not correct. Did you use the correcot 32/64-Bit version? try both
And download the Sun-Java not the openJava.
vanessa
Post by vanessa »
I installed sun-java6-jre package from the Debian Squeezy repository
$ java -version
java version "1.6.0_26"
Java(TM) SE Runtime Environment (build 1.6.0_26-b03)
Java HotSpot(TM) Server VM (build 20.1-b02, mixed mode)
./runHELI-X.sh
        at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:39)
        at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:27)
        at java.lang.reflect.Constructor.newInstance(Constructor.java:513)
        at java.lang.Class.newInstance0(Class.java:355)
        at java.lang.Class.newInstance(Class.java:308)
        at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
        at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:641)
        at java.awt.EventQueue.access$000(EventQueue.java:84)
        at java.awt.EventQueue$1.run(EventQueue.java:602)
        at java.awt.EventQueue$1.run(EventQueue.java:600)
        at java.security.AccessControlContext$1.doIntersectionPrivilege(AccessControlContext.java:87)
        at java.awt.EventQueue.dispatchEvent(EventQueue.java:611)
        at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:269)
        at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:184)
        at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:174)
        at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:169)
        at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:161)
        at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
No Joystick found
there are no changes..........
PS I use 32-bіt version
sbulgher
Post by sbulgher »
Hello Vanessa
I had the same problem with heli-x 4.1(Ubuntu 12.04 32bit). I just replaced the folder heli-x/libs/jinput with the version of heli-x V4.0 (by the way this version was running fine on the same system) and fixed so the problem.
Regards Stefan
vanessa
Post by vanessa »
Hello Stefan
Where can I download version 4.0?
sbulgher
Post by sbulgher »
Hello Vanessa
See this post at the end:
(link to the java jinput project)
viewtopic.php?f=9&t=635
Regards Stefan
vanessa
Post by vanessa »
Thank you for your advice helped me
cristianpark
Post by cristianpark »
I experienced the same problem and searching on google I found this thread [1] that says you have to update libs/jinput/linux-i586/jinput-linux.so with newer version of jinput (the link provided on the post doesn't work anymore, yoy should use http://www.newdawnsoftware.com/resource ... t/?C=M;O=D)
Heli-X devs should include latest version of jinpu-linux.so with the releases of Heli-X in order to avoid this, even though it's great we can have Linux version of this simulator that seems so good (I'm a starter in RC helis), I'll try to buy full version to support devs
[1] viewtopic.php?f=9&t=9&st=0&sk=t&sd=a&start=10
the current download of the demo version contains the newest jinput library. I hope it works now for everybody. Let me know if you encounter any problems.
Ben Hudson
Post by Ben Hudson »
I'm having a similar problem, running the latest version of Linux Mint Debian Edition (64bit) and HELI-X. I'm using a wireless XBox 360 controller, which is working fine in jtest (and in other games).
It seems to be recognised, though the plugin claims to have 12 controllers... -
./runHELI-X64.sh
Set new path for the resources: /home/ben/Downloads/HELI-X41/resources/
Set new path for the user files: /home/ben/Downloads/HELI-X41/files/
Couldn't find tag "Resolution" in file "/home/ben/Downloads/HELI-X41/files/Application/ViewSettings.xml"
Found 5 display modes
17-Nov-2012 20:32:37 net.java.games.input.ControllerEnvironment log
INFO: Linux plugin claims to have found 12 controllers
Controller found: Name: Generic X-Box pad(Generic X-Box pad)
Controller found: Name: Generic X-Box pad(Generic X-Box padX)
Controller found: Name: Generic X-Box pad(Generic X-Box padXX)
Controller found: Name: Generic X-Box pad(Generic X-Box padXXX)
Using Stick Generic X-Box pad
Digital component found:A
Digital component found:B
Digital component found:X
Digital component found:Y
Digital component found:Left Thumb
Digital component found:Right Thumb
Digital component found:Select
Digital component found:Unknown
Digital component found:Mode
Digital component found:Left Thumb 3
Digital component found:Right Thumb 3
Analog component found:x
Analog component found:y
Analog component found:z
Analog component found:rx
Analog component found:ry
Analog component found:rz
Digital component found:pov
Controller configuration file found: /home/ben/Downloads/HELI-X41/files/controller/GenericX-Boxpad.xml
Controller configuration file /home/ben/Downloads/HELI-X41/files/controller/GenericX-Boxpad.xml read
ben@comatus:~/Downloads/HELI-X41$ ./runHELI-X64.sh
17-Nov-2012 20:42:55 net.java.games.input.ControllerEnvironment log
Exception occurred during event dispatching:
java.lang.NullPointerException
	at a.a.a.c.c.k.a(Unknown Source)
	at a.a.a.c.c.c.actionPerformed(Unknown Source)
	at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2012)
	at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2335)
	at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:404)
	at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259)
	at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:252)
	at java.awt.Component.processMouseEvent(Component.java:6268)
	at javax.swing.JComponent.processMouseEvent(JComponent.java:3267)
	at java.awt.Component.processEvent(Component.java:6033)
	at java.awt.Container.processEvent(Container.java:2045)
	at java.awt.Component.dispatchEventImpl(Component.java:4629)
	at java.awt.Container.dispatchEventImpl(Container.java:2103)
	at java.awt.Component.dispatchEvent(Component.java:4455)
	at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4633)
	at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4297)
	at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4227)
	at java.awt.Container.dispatchEventImpl(Container.java:2089)
	at java.awt.Window.dispatchEventImpl(Window.java:2517)
	at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:649)
	at java.awt.EventQueue.access$000(EventQueue.java:96)
	at java.awt.EventQueue$1.run(EventQueue.java:608)
	at java.awt.EventQueue$1.run(EventQueue.java:606)
	at java.security.AccessControlContext$1.doIntersectionPrivilege(AccessControlContext.java:116)
	at java.awt.EventQueue$2.run(EventQueue.java:622)
	at java.awt.EventQueue$2.run(EventQueue.java:620)
	at java.awt.EventQueue.dispatchEvent(EventQueue.java:619)
	at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:194)
	at java.awt.Dialog$1.run(Dialog.java:1072)
	at java.awt.Dialog$3.run(Dialog.java:1126)
	at java.awt.Dialog.show(Dialog.java:1124)
	at java.awt.Component.show(Component.java:1551)
	at java.awt.Component.setVisible(Component.java:1503)
	at java.awt.Window.setVisible(Window.java:881)
	at java.awt.Dialog.setVisible(Dialog.java:1011)
	at a.a.a.c.c.c.a(Unknown Source)
	at a.a.a.c.c.c.<init>(Unknown Source)
	at a.a.a.c.c.k.actionPerformed(Unknown Source)
	at a.a.a.c.c.k.<init>(Unknown Source)
	at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:647)
	at java.awt.EventQueue.dispatchEvent(EventQueue.java:617)
... but then when trying to configure the controls nothing happens. I updated to the latest version of jinput but I think it is just the same as the version in the HELI-X download.
Also, sorry to be such a total novice, but I'm planning to use this to learn how to fly a quadcopter and the configuration settings are aimed at collective pitch helicopters - which stick should I set as which to get a Mode II setup?
Thanks,
Ben
(PS. There aren't many Linux flight sims that do quadrotors, you should advertise it more as such.)
Ben
