HELI-X 4.1 closes
cristianpark
HELI-X 4.1 closes
Post by cristianpark »
Hi guys
I had Demo version running well on my Arch Linux box but after full registration, HELI-X doesn't start again.
I'm getting
 sh /PATH/HELI-X41/runHELI-X.sh
Set new path for the resources: /PATH/HELI-X41/resources/
Set new path for the user files: /PATH/HELI-X41/files/
Couldn't find tag "Resolution" in file "/PATH/HELI-X41/files/Application/ViewSettings.xml"
And the program quits, I searched for the file and it doesn't exists at all
Do you know how can I solve this?
Thanks in advance
PD: Michael, I'm Cristian from spanish translation :D :D
cristianpark
Re: HELI-X 4.1 closes
I just install a new demo and change resolution settings to see if there was some ViewSettings.xml file generated, it is with this contents http://pastebin.com/WJNxXshV, I copy it to the registered version and what I get now is
$ sh /PATH/HELI-X41/runHELI-X.sh
So, it exits without any error message (previously I had sound and controller successful configurated)
From the splash I can see 4.1.1205 and then it closes. I see on libs/HELI-X that there's one jar with _back postfix and one without it, the back is about 24MB and the 'new one' is about 2 MB, maybe this has something to do with the problem
Do you know if there is any log or any way to execute HELI-X on debug mode?
... we fix it by email ...
cristianpark
Thanks Michael
I thought this was a general problem. I'll wait your email
Email sent. ;-)
