Problem loading airports.
Simon
Post by Simon »
Sometimes they load, sometimes not.
Of the 6 images, anywhere between 0 and 6 images will load.
Sometimes restarting the program fixes the problem, but this is not foolproof.
I've just flown "3d masters HD" and found that the "top" was a replica of the ground? Now that
was confusing.
All images seem to be labeled correctly and are in the correct folders.
Any ideas -- this is very frustrating.
Running windows 8 :cry:
Thanks.
Simon.
trex-450 pro 3gx - Need a bigger heli.
Re: Problem loading airports.
this is likely to be a problem of the memory on your graphics adapter. Use SkyBox or SkyBox1024 airports instead the HD versions.
