Changing Position Pointer colour
Posted: 12 Jun 2013 05:36
by paolofcantoni
I'm not sure if this should be in this forum or the Airports...
The default Position Pointer colouring is fine for normal use. However, when in training, especially when the circle goes "Red" it can be hard to see. How can I change the colour of the position pointer? I'm a computer technical person :geek: so can edit files directly. A "vivid blue" might do the trick for me... :P
Because the problem of depth perception is common to all simulators, I use the position pointer to tell me how far I'm away from the edge of the circle.
TIA,
Paolo
Re: Changing Position Pointer colour
Posted: 12 Jun 2013 23:26
Sorry, the groundpointer is stored inside HELI-X, so you can't change it.
Posted: 13 Jun 2013 06:03
by paolofcantoni
Can this be considered for a future release?
Paolo
