reaction training and camera
iltrex
Post by iltrex »
In reaction training, if you crash behind the start position, the camera has not enough time to center the "new" elicopter (on the other side) so you crash.
If possibiel, I think the two options would be
1. reset the camera to the beginning position before resetting the heli
2. put the new eli in front of the actual camera position.
thank you for your wonderful work!
Re: reaction training and camera
Thanks, I understand the problem. The current solution is to switch off the soft camera mode...
