PPM on Windows
albal
PPM on Windows
Post by albal »
I am using a Reality Craft controller. It is working fine with the software that came with it but I have the one for Planes. However, can I use this controller with Heli-X. In settings I do not see the bars move though the console window seems to see the controller:
Set new path for the resources: C:/HELI-X4/resources/
Set new path for the user files: C:/HELI-X4/files/
Couldn't find tag "WindowSettings" in file "C:/HELI-X4/files/Application/Applica
tionSettings.xml"
Couldn't find tag "InfoWindow" in file "C:/HELI-X4/files/Application/Application
Settings.xml"
Couldn't find tag "ChatWindow" in file "C:/HELI-X4/files/Application/Application
Settings.xml"
Couldn't find tag "Resolution" in file "C:/HELI-X4/files/Application/ViewSetting
s.xml"
Found 46 display modes
Oct 14, 2013 1:18:52 PM net.java.games.input.DefaultControllerEnvironment getCon
trollers
WARNING: Found unknown Windows version: Windows 8
trollers
WARNING: Attempting to use default windows plug-in.
Controller found: Name: PPM(PPM)
Using Stick PPM
Analog component found:Y Rotation
Analog component found:X Rotation
Analog component found:Y Axis
Analog component found:X Axis
Analog component found:Z Rotation
Analog component found:Z Axis
Digital component found:Hat Switch
Digital component found:Button 3
Digital component found:Button 4
Digital component found:Button 5
Digital component found:Button 6
Digital component found:Button 7
Digital component found:Button 8
Digital component found:Button 9
Digital component found:Button 10
Digital component found:Button 11
Controller configuration file found: C:/HELI-X4/files/controller/PPM.xml
Controller configuration file C:/HELI-X4/files/controller/PPM.xml read
Also isn't it about time you detecting windows 8. It has been out a year and soon 8.1 will be available :-)
Re: PPM on Windows
Please do the calibration procedure: Press the button on the left hand side od the configuration window and perform as written in the window.
