Greetings,
As a new member to this forum, I have MUCH to learn. I have downloaded the demo version of Heli-x, but can find no way to avoid black screens when I try to use the limited features. Also, I want to BUY the registration, but can find nowhere to find out about the company. Can anyone PLEASE help?
Thank you, much....
Joseph Walburn, Athens, OH USA
Win 7 Black Screen
Re: Win 7 Black Screen
Hello
the alck screen are likely due to the fact that your graphics adapter can not use openGL. please update the graphics driver from the webseite of the vendor of the graphics adapter. Buying the full version makes only sense when the demo version is running and you are satisfied. In this case you ca find the information at www.heli-x.net
aerospace1248
Michael....
Thanks a load for your help. I followed your instructions, but as yet have not checked to see if the program is working. Since you seem knowledgable, do you know HOW I can ask questions about HOW to USE the DEMO? For example, WHICH aircraft work, and WHICH airports work with the demo? I have other questions before I buy, but there just seems to be no real support for a customer with questions.
Thanks again....hope I can return the favor sometime.
Joe Walburn, Athens, OH USA
for the helicopters (it is similar for the airports): Open the helicopter selection window and go through the possibilities. When a helicopter is selectable, the "open" button is usuable otherwise it is unusable. Or - just read the text in the nag screen.
I am actually running Windows XP but I have all of the latest available drivers including the latest available Graphic Drivers which has Open GL 6.3. I originally downloaded the Demo and after procuring the correct cable for a DX8 I could not open it because, according to the console, I did not have GSLS and Open GL 2.0; Hence the down load of the new Drivers.
Now when I try to run Heli-X the console appears to scroll but I only get the "black screen" on what is supposed to be the display window.
Examining the ouput on the console it is clear that the program is looping and trying to Render an image but I have the following Exception being thrown:
@ java.lang.Thread.run (Unknown Source)
Exception in Render thread
com.jme3.renderer.RenderException: Cannot upload texture Image The maximum suported texture resolution is 2048.
In desparation I have tried, switching monitor display resolution, refresh rate, minimizing/recalling the display window, and even switching from a newer HD monitor to the original monitor that came with this PC (many many years ago) No luck.
I am not running the display window maximized and mainly use this PC to run my simulations.
I'm hopeful someone can help. Should I download an earlier version?
@Rogue: please name the graphics card you are using...
RADEON X300 Series by ATI Technologies
Location is PC bus1, device0, function 0
It is 32 bit and I did download the 32 bit Heli-X version
Specific OpenGL version is listed as 6.14.10.8543
I too am getting a black screen, but I also get sound which is positive.
My controller (hobbyKing 6ch) as recommended is plugged in and ready.
The two windows I see are 1. A registry window where code is running at such a rate I can't read it and 2. the flight sim window where I have sound playing back but nothing in view - just a black window.
Here are my system specs;
System Information
Time of this report: 3/29/2014, 16:59:51
Machine name: DELL-PC
Operating System: Windows 7 Professional 32-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.130828-1532)
Language: English (Regional Setting: English)
System Manufacturer: Dell Inc.
System Model: MXP061
BIOS: Phoenix ROM BIOS PLUS Version 1.10 A06
Processor: Intel(R) Core(TM)2 CPU T7600 @ 2.33GHz (2 CPUs), ~2.3GHz
Memory: 4096MB RAM
Available OS Memory: 3326MB RAM
Page File: 3165MB used, 3486MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 32bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: ATI Mobility Radeon X1800
Manufacturer: ATI Technologies Inc.
Chip type: ATI Radeon Graphics Processor (0x7102)
DAC type: Internal DAC(400MHz)
Device Key: Enum\PCI\VEN_1002&DEV_7102&SUBSYS_200A1028&REV_00
Display Memory: 1661 MB
Dedicated Memory: 254 MB
Shared Memory: 1407 MB
Current Mode: 1680 x 1050 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: unknown
Monitor Id: LPL3D00
Native Mode: 1680 x 1050(p) (59.994Hz)
Output Type: Internal
Driver Name: atiumdag.dll,atiumdva.cap,atitmmxx.dll
Driver File Version: 7.14.0010.0630 (English)
Driver Version: 8.561.0.0
DDI Version: 9Ex
Driver Model: WDDM 1.0
Driver Attributes: Final Retail
Driver Date/Size: 12/1/2008 20:29:34, 4033536 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B71EE2-3242-11CF-EE71-0000A1C2CA35}
Vendor ID: 0x1002
Device ID: 0x7102
SubSys ID: 0x200A1028
Revision ID: 0x0000
Driver Strong Name: oem9.inf:ATI.Mfg:ati2mtag_M58:8.561.0.0:pci\ven_1002&dev_7102
Rank Of Driver: 00F62001
Video Accel: ModeMPEG2_A ModeMPEG2_C
Deinterlace Caps: {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{3C5323C1-6FB7-44F5-9081-056BF2EE449D}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{552C0DAD-CCBC-420B-83C8-74943CF9F1A6}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
D3D9 Overlay: Not Supported
DXVA-HD: Not Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Description: Speakers (SigmaTel High Definition Audio CODEC)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_8384&DEV_7680&SUBSYS_102801BF&REV_1036
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: sthda.sys
Driver Version: 5.10.4995.0001 (English)
WHQL Logo'd: Yes
Date and Size: 3/24/2006 17:34:30, 1156648 bytes
Other Files:
Driver Provider: SigmaTel
HW Accel Level: Basic
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Description: Speakers (Rode Podcaster)
Default Sound Playback: No
Default Voice Playback: No
Hardware ID: USB\VID_19F7&PID_0001&REV_0009&MI_00
Manufacturer ID: 65535
Product ID: 65535
Type: WDM
Driver Name: USBAUDIO.sys
Driver Version: 6.01.7601.18208 (English)
WHQL Logo'd: Yes
Date and Size: 7/12/2013 10:07:52, 80896 bytes
Other Files:
Driver Provider: Microsoft
Cap Flags: 0xF1F
HW Memory: 0
Sound Capture Devices
Description: Microphone (HD Pro Webcam C910)
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x1
Format Flags: 0xFFFFF
Description: Line In (SigmaTel High Definition Audio CODEC)
Default Sound Capture: No
Default Voice Capture: No
Cap Flags: 0x1
Description: Internal Mic (SigmaTel High Definition Audio CODEC)
Cap Flags: 0x1
Description: External Mic (SigmaTel High Definition Audio CODEC)
Cap Flags: 0x1
Description: Microphone (Rode Podcaster)
Cap Flags: 0x1
Description: Alt Mic (SigmaTel High Definition Audio CODEC)
Cap Flags: 0x1
Description: Alt Line In (SigmaTel High Definition Audio CODEC)
Cap Flags: 0x1
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: Microsoft eHome Infrared Transceiver
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x045E, 0x006D
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: ART
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x0603, 0x1A13
FF Driver: n/a
Device Name: Rode Podcaster
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x19F7, 0x0001
FF Driver: n/a
Device Name: Bluetooth Mouse
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x046D, 0xB004
FF Driver: n/a
Device Name: XPS M2010 Keyboard
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x413C, 0x8125
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x27CB
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 11/27/2013 01:14:25, 258560 bytes
| Driver: usbd.sys, 11/27/2013 01:13:33, 6016 bytes
+-+ USB Input Device
| | Matching Device ID: generic_hid_device
| | Service: HidUsb
| | OEMData: 01 00 88 11 00 00 00 00
| | Driver: hidusb.sys, 11/20/2010 21:29:03, 24064 bytes
| | Driver: hidclass.sys, 7/3/2013 03:36:24, 55808 bytes
| | Driver: hidparse.sys, 7/3/2013 03:36:22, 25728 bytes
| +-+ HID-compliant game controller
| | | Matching Device ID: hid_device_system_game
Gameport Devices
PS/2 Devices
+ Standard PS/2 Keyboard
| Matching Device ID: *pnp0303
| Service: i8042prt
| Driver: i8042prt.sys, 7/13/2009 23:11:24, 80896 bytes
| Driver: kbdclass.sys, 7/14/2009 01:20:36, 42576 bytes
+ Microsoft eHome Remote Control Keyboard keys
| Matching Device ID: hid\irdevicev2&col05
| Service: kbdhid
| Driver: kbdhid.sys, 11/20/2010 21:29:03, 28160 bytes
+ Microsoft eHome MCIR Keyboard
| Matching Device ID: hid\irdevicev2&col06
| Service: kbdhid
+ Microsoft eHome MCIR 109 Keyboard
| Matching Device ID: hid\irdevicev2&col07
| Service: kbdhid
+ HID Keyboard Device
| Vendor/Product ID: 0x0000, 0x0812
| Matching Device ID: hid_device_system_keyboard
| Service: kbdhid
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
+ HID-compliant mouse
| Matching Device ID: hid_device_system_mouse
| Service: mouhid
| Driver: mouhid.sys, 7/13/2009 23:45:08, 26112 bytes
| Driver: mouclass.sys, 7/14/2009 01:20:44, 41552 bytes
+ Dell HID-compliant Bluetooth Mouse
| Vendor/Product ID: 0x0000, 0x0B00
| Matching Device ID: hid\{00001124-0000-1000-8000-00805f9b34fb}_vid&0002046d_pid&b004&col01
| Upper Filters: LMouFilt
| Lower Filters: LHidFilt
| Service: mouhid
| Driver: LHidFilt.Sys, 10/11/2006 11:43:52, 25216 bytes
| Driver: LMouFilt.Sys, 10/11/2006 11:43:52, 25344 bytes
| Driver: KHALMNPR.Exe, 10/11/2006 11:32:34, 94208 bytes
| Driver: WdfCoInstaller01005.dll, 8/30/2006 03:47:16, 1447904 bytes
| Service: mouhid
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
| Driver: termdd.sys, 11/20/2010 21:29:03, 53120 bytes
| Driver: sermouse.sys, 7/13/2009 23:45:08, 19968 bytes
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 140.7 GB
Total Space: 228.8 GB
File System: NTFS
Model: INTEL SSDSC2BW240A3H
Drive: D:
Model: TEAC DVD+-RW DVW28SLZ ATA Device
Driver: c:\windows\system32\drivers\cdrom.sys, 6.01.7601.17514 (English), 11/20/2010 21:29:03, 108544 bytes
System Devices
Name: Intel(R) 82801G (ICH7 Family) Ultra ATA Storage Controllers - 27DF
Device ID: PCI\VEN_8086&DEV_27DF&SUBSYS_01BF1028&REV_01\3&2B8E0B4B&0&F9
Driver: C:\Windows\system32\DRIVERS\intelide.sys, 6.01.7600.16385 (English), 7/14/2009 01:20:36, 15424 bytes
Driver: C:\Windows\system32\DRIVERS\pciidex.sys, 6.01.7600.16385 (English), 7/14/2009 01:19:03, 42560 bytes
Driver: C:\Windows\system32\DRIVERS\atapi.sys, 6.01.7600.16385 (English), 7/14/2009 01:26:15, 21584 bytes
Driver: C:\Windows\system32\DRIVERS\ataport.sys, 6.01.7601.18231 (English), 8/5/2013 01:56:47, 133056 bytes
Name: Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27CB
Device ID: PCI\VEN_8086&DEV_27CB&SUBSYS_01BF1028&REV_01\3&2B8E0B4B&0&EB
Driver: C:\Windows\system32\drivers\usbuhci.sys, 6.01.7601.18328 (English), 11/27/2013 01:13:36, 24064 bytes
Driver: C:\Windows\system32\drivers\usbport.sys, 6.01.7601.18328 (English), 11/27/2013 01:13:46, 284672 bytes
Driver: C:\Windows\system32\drivers\usbhub.sys, 6.01.7601.18328 (English), 11/27/2013 01:14:25, 258560 bytes
Name: Intel(R) 82801 PCI Bridge - 2448
Device ID: PCI\VEN_8086&DEV_2448&SUBSYS_01BF1028&REV_E1\3&2B8E0B4B&0&F0
Driver: C:\Windows\system32\DRIVERS\pci.sys, 6.01.7601.17514 (English), 11/20/2010 21:29:03, 153984 bytes
Name: ATI Mobility Radeon X1800
Device ID: PCI\VEN_1002&DEV_7102&SUBSYS_200A1028&REV_00\4&1A01D617&0&0008
Driver: C:\Windows\system32\DRIVERS\atikmdag.sys, 7.01.0001.0849 (English), 12/1/2008 22:14:34, 4179968 bytes
Driver: C:\Windows\system32\DRIVERS\ativcaxx.cpa, 8/23/2006 22:26:58, 328162 bytes
Driver: C:\Windows\system32\DRIVERS\ativcaxx.vp, 8/23/2006 22:26:58, 929 bytes
Driver: C:\Windows\system32\DRIVERS\ativvpxx.vp, 9/9/2007 03:37:08, 52400 bytes
Driver: C:\Windows\system32\DRIVERS\ativpkxx.vp, 5/30/2007 16:37:38, 2096 bytes
Driver: C:\Windows\system32\DRIVERS\ativokxx.vp, 5/30/2007 16:37:38, 2096 bytes
Driver: C:\Windows\system32\DRIVERS\ativdkxx.vp, 4/18/2007 13:19:50, 2096 bytes
Driver: C:\Windows\system32\DRIVERS\ati2erec.dll, 1.00.0000.0016 (English), 12/1/2008 19:43:00, 53248 bytes
Driver: C:\Windows\system32\atiumdag.dll, 7.14.0010.0630 (English), 12/1/2008 20:29:34, 4033536 bytes
Driver: C:\Windows\system32\atiumdva.dll, 7.14.0010.0208 (English), 12/1/2008 20:09:18, 4754432 bytes
Driver: C:\Windows\system32\atitmmxx.dll, 6.14.0011.0019 (English), 12/1/2008 20:46:12, 159744 bytes
Driver: C:\Windows\system32\atiicdxx.dat, 10/30/2008 14:45:42, 180720 bytes
Driver: C:\Windows\system32\atiumdva.dat, 12/1/2008 20:08:40, 3107788 bytes
Driver: C:\Windows\system32\amdpcom32.dll, 7.14.0010.0018 (English), 12/1/2008 19:56:38, 50688 bytes
Driver: C:\Windows\system32\atiadlxx.dll, 6.14.0010.1021 (English), 12/1/2008 19:56:16, 98304 bytes
Driver: C:\Windows\system32\atiumdva.cap, 12/1/2008 20:08:40, 69112 bytes
Driver: C:\Windows\system32\Ati2evxx.exe, 6.14.0010.4213 (English), 12/1/2008 20:44:12, 720896 bytes
Driver: C:\Windows\system32\Ati2evxx.dll, 6.14.0010.4177 (English), 12/1/2008 20:45:26, 274432 bytes
Driver: C:\Windows\system32\atipdlxx.dll, 6.14.0010.2543 (English), 12/1/2008 20:46:00, 331776 bytes
Driver: C:\Windows\system32\Oemdspif.dll, 6.15.0005.0001 (English), 12/1/2008 20:45:48, 262144 bytes
Driver: C:\Windows\system32\ati2edxx.dll, 6.14.0010.2513 (English), 12/1/2008 20:45:38, 43520 bytes
Driver: C:\Windows\system32\ATIDEMGX.dll, 2.00.3257.28424 (English), 12/1/2008 20:47:30, 425984 bytes
Driver: C:\Windows\system32\atioglxx.dll, 6.14.0010.8304 (English), 12/1/2008 20:17:28, 10981376 bytes
Driver: C:\Windows\system32\amdcaldd.dll, 6.14.0010.0145 (English), 12/1/2008 19:53:56, 3256320 bytes
Driver: C:\Windows\system32\amdcalrt.dll, 6.14.0010.0145 (English), 12/1/2008 19:56:44, 57344 bytes
Driver: C:\Windows\system32\amdcalcl.dll, 6.14.0010.0145 (English), 12/1/2008 19:56:32, 53248 bytes
Driver: C:\Windows\atiogl.xml, 10/17/2008 14:19:10, 15079 bytes
Name: Intel(R) 82801G (ICH7 Family) SMBus Controller - 27DA
Device ID: PCI\VEN_8086&DEV_27DA&SUBSYS_01BF1028&REV_01\3&2B8E0B4B&0&FB
Driver: n/a
Name: Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27CA
Device ID: PCI\VEN_8086&DEV_27CA&SUBSYS_01BF1028&REV_01\3&2B8E0B4B&0&EA
Name: Broadcom NetXtreme 57xx Gigabit Controller
Device ID: PCI\VEN_14E4&DEV_16F7&SUBSYS_01BF1028&REV_21\4&6E17667&0&00E2
Driver: C:\Windows\system32\DRIVERS\b57xp32.sys, 8.48.0000.0000 (English), 10/26/2005 10:01:02, 142720 bytes
Name: High Definition Audio Controller
Device ID: PCI\VEN_8086&DEV_27D8&SUBSYS_01BF1028&REV_01\3&2B8E0B4B&0&D8
Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 6.01.7601.17514 (English), 11/20/2010 21:29:03, 108544 bytes
Name: Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27C9
Device ID: PCI\VEN_8086&DEV_27C9&SUBSYS_01BF1028&REV_01\3&2B8E0B4B&0&E9
Name: Ricoh xD-Picture Card Controller
Device ID: PCI\VEN_1180&DEV_0852&SUBSYS_01BF1028&REV_04\4&1F4B3DF&0&0DF0
Driver: C:\Windows\system32\DRIVERS\rixdptsk.sys, 6.10.0001.0004 (Japanese), 6/25/2009 16:25:58, 38400 bytes
Driver: C:\Windows\system32\rixdicon.dll, 1.00.0001.0001 (Japanese), 7/25/2007 12:48:58, 172032 bytes
Name: Intel(R) 82801G (ICH7 Family) PCI Express Root Port - 27D6
Device ID: PCI\VEN_8086&DEV_27D6&SUBSYS_01BF1028&REV_01\3&2B8E0B4B&0&E3
Name: Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27C8
Device ID: PCI\VEN_8086&DEV_27C8&SUBSYS_01BF1028&REV_01\3&2B8E0B4B&0&E8
Name: Ricoh SD/MMC Host Controller
Device ID: PCI\VEN_1180&DEV_0843&SUBSYS_01BF1028&REV_00\4&1F4B3DF&0&0BF0
Driver: C:\Windows\system32\DRIVERS\rimmptsk.sys, 6.10.0001.0003 (Japanese), 6/25/2009 16:58:10, 48128 bytes
Name: Intel(R) 82801G (ICH7 Family) PCI Express Root Port - 27D4
Device ID: PCI\VEN_8086&DEV_27D4&SUBSYS_01BF1028&REV_01\3&2B8E0B4B&0&E2
Name: Intel(R) ICH7MDH SATA RAID Controller
Device ID: PCI\VEN_8086&DEV_27C6&SUBSYS_01BF1028&REV_01\3&2B8E0B4B&0&FA
Driver: C:\Windows\system32\DRIVERS\iaStorV.sys, 8.06.0002.1014 (English), 3/11/2011 05:38:51, 332160 bytes
Name: SDA Standard Compliant SD Host Controller
Device ID: PCI\VEN_1180&DEV_0822&SUBSYS_01BF1028&REV_18\4&1F4B3DF&0&0AF0
Driver: C:\Windows\system32\DRIVERS\sdbus.sys, 6.01.7601.17514 (English), 11/20/2010 21:29:03, 84992 bytes
Name: Intel(R) 82801G (ICH7 Family) PCI Express Root Port - 27D2
Device ID: PCI\VEN_8086&DEV_27D2&SUBSYS_01BF1028&REV_01\3&2B8E0B4B&0&E1
Name: Intel(R) 82801GHM (ICH7-M/U DH) LPC Interface Controller - 27BD
Device ID: PCI\VEN_8086&DEV_27BD&SUBSYS_01BF1028&REV_01\3&2B8E0B4B&0&F8
Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 6.01.7600.16385 (English), 7/14/2009 01:20:43, 13888 bytes
Name: Ricoh Memory Stick Controller
Device ID: PCI\VEN_1180&DEV_0592&SUBSYS_01BF1028&REV_09\4&1F4B3DF&0&0CF0
Driver: C:\Windows\system32\snymsico.dll, 1.00.0000.9120 (English), 9/4/2004 03:00:00, 90112 bytes
Driver: C:\Windows\system32\DRIVERS\rimsptsk.sys, 6.10.0001.0003 (Japanese), 6/25/2009 16:10:48, 44544 bytes
Name: Intel(R) 82801G (ICH7 Family) PCI Express Root Port - 27D0
Device ID: PCI\VEN_8086&DEV_27D0&SUBSYS_01BF1028&REV_01\3&2B8E0B4B&0&E0
Name: Mobile Intel(R) 945GM/GU/PM/GMS/940GML/943GML and Intel(R) 945GT Express PCI Express Root Port - 27A1
Device ID: PCI\VEN_8086&DEV_27A1&SUBSYS_01BF1028&REV_03\3&2B8E0B4B&0&08
Name: Ricoh 1394 OHCI Compliant Host Controller
Device ID: PCI\VEN_1180&DEV_0552&SUBSYS_01BF1028&REV_09\4&1F4B3DF&0&09F0
Driver: C:\Windows\system32\DRIVERS\1394ohci.sys, 6.01.7601.17514 (English), 11/20/2010 21:29:03, 164864 bytes
Name: Intel(R) PRO/Wireless 3945ABG Network Connection
Device ID: PCI\VEN_8086&DEV_4222&SUBSYS_10218086&REV_02\4&32E4E00E&0&00E1
Driver: n/a
Name: Intel(R) 82801G (ICH7 Family) USB2 Enhanced Host Controller - 27CC
Device ID: PCI\VEN_8086&DEV_27CC&SUBSYS_01BF1028&REV_01\3&2B8E0B4B&0&EF
Driver: C:\Windows\system32\drivers\usbehci.sys, 6.01.7601.18328 (English), 11/27/2013 01:13:41, 43520 bytes
Name: Mobile Intel(R) 945GM/GU/PM/GMS/940GML/943GML and Intel(R) 945GT Express Processor to DRAM Controller - 27A0
Device ID: PCI\VEN_8086&DEV_27A0&SUBSYS_01BF1028&REV_03\3&2B8E0B4B&0&00
Driver: n/a
Name: Ricoh R/RL/5C476(II) or Compatible CardBus Controller
Device ID: PCI\VEN_1180&DEV_0476&SUBSYS_01BF1028&REV_B4\4&1F4B3DF&0&08F0
Driver: C:\Windows\system32\DRIVERS\pcmcia.sys, 6.01.7600.16385 (English), 7/14/2009 01:19:03, 180288 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.01.7601.17514
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.01.7601.17514
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.01.7601.17514
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.01.7600.16385
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.01.7600.16385
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.01.7601.17514
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.01.7601.18221
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.01.7600.16385
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.01.7600.16385
DV Muxer,0x00400000,0,0,qdv.dll,6.06.7601.17514
Color Space Converter,0x00400001,1,1,quartz.dll,6.06.7601.17713
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.7601.17514
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,12.00.7601.17514
AVI Splitter,0x00600000,1,1,quartz.dll,6.06.7601.17713
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.7601.17713
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.7601.17528
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,12.00.9200.16426
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.7601.17528
Microsoft TV Captions Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7601.17715
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17713
CBVA DMO wrapper filter,0x00200000,1,1,cbva.dll,6.01.7601.17514
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.7601.17713
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.7601.17514
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.7601.17528
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.7601.17514
SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.7601.17528
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17713
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.7601.17713
DV Splitter,0x00600000,1,2,qdv.dll,6.06.7601.17514
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.7601.17713
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,6.01.7601.17514
ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.7601.17713
Video Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17713
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.7601.17528
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.06.7601.17835
Video Port Manager,0x00600000,2,1,quartz.dll,6.06.7601.17713
Video Renderer,0x00400000,1,0,quartz.dll,6.06.7601.17713
VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.7601.17514
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.7601.17514
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.01.7601.17514
File writer,0x00200000,1,0,qcap.dll,6.06.7601.17514
iTV Data Sink,0x00600000,1,0,itvdata.dll,6.06.7601.17514
iTV Data Capture filter,0x00600000,1,1,itvdata.dll,6.06.7601.17514
DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.7601.17835
Microsoft TV Subtitles Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7601.17715
Overlay Mixer2,0x00200000,1,1,qdvd.dll,6.06.7601.17835
AVI Draw,0x00600064,9,1,quartz.dll,6.06.7601.17713
RDP DShow Redirection Filter,0xffffffff,1,0,DShowRdpFilter.dll,
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
WST Pager,0x00200000,1,1,WSTPager.ax,6.06.7601.17514
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
DV Video Decoder,0x00800000,1,1,qdv.dll,6.06.7601.17514
SampleGrabber,0x00200000,1,1,qedit.dll,6.06.7601.18386
Null Renderer,0x00200000,1,0,qedit.dll,6.06.7601.18386
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.7601.17514
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,6.01.7601.17514
StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.7601.17528
Smart Tee,0x00200000,1,2,qcap.dll,6.06.7601.17514
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.06.7601.17835
AVI Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17713
NetBridge,0x00200000,2,0,netbridge.dll,6.01.7601.17514
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.06.7601.17713
Wave Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
MIDI Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
Multi-file Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
File stream renderer,0x00400000,1,1,quartz.dll,6.06.7601.17713
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,6.01.7140.0000
StreamBufferSink2,0x00200000,0,0,sbe.dll,6.06.7601.17528
AVI Mux,0x00200000,1,0,qcap.dll,6.06.7601.17514
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.06.7601.17713
File Source (Async.),0x00400000,0,1,quartz.dll,6.06.7601.17713
File Source (URL),0x00400000,0,1,quartz.dll,6.06.7601.17713
Media Center Extender Encryption Filter,0x00200000,2,2,Mcx2Filter.dll,6.01.7601.17514
AudioRecorder WAV Dest,0x00200000,0,0,WavDest.dll,
AudioRecorder Wave Form,0x00200000,0,0,WavDest.dll,
SoundRecorder Null Renderer,0x00200000,0,0,WavDest.dll,
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.06.7601.17514
Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.01.7601.17514
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.7601.17669
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.06.7601.17713
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
WDM Streaming Data Transforms:
Creative SoundFont Synthesizer,0x00000000,0,0,,
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.01.7600.16385
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.01.7600.16385
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.01.7600.16385
DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.7601.17514
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.7601.17713
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.06.7601.17514
Logitech Video (I420),0x00200000,1,1,qcap.dll,6.06.7601.17514
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.06.7601.17514
Microsoft RLE,0x00200000,1,1,qcap.dll,6.06.7601.17514
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.06.7601.17514
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,6.01.7600.16385
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,6.01.7600.16385
IMA ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17713
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17713
GSM 6.10,0x00200000,1,1,quartz.dll,6.06.7601.17713
CCITT A-Law,0x00200000,1,1,quartz.dll,6.06.7601.17713
CCITT u-Law,0x00200000,1,1,quartz.dll,6.06.7601.17713
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.06.7601.17713
Audio Capture Sources:
Microphone (HD Pro Webcam C910),0x00200000,0,0,qcap.dll,6.06.7601.17514
Alt Line In (SigmaTel High Defi,0x00200000,0,0,qcap.dll,6.06.7601.17514
Alt Mic (SigmaTel High Definiti,0x00200000,0,0,qcap.dll,6.06.7601.17514
External Mic (SigmaTel High Def,0x00200000,0,0,qcap.dll,6.06.7601.17514
Internal Mic (SigmaTel High Def,0x00200000,0,0,qcap.dll,6.06.7601.17514
Line In (SigmaTel High Definiti,0x00200000,0,0,qcap.dll,6.06.7601.17514
Microphone (Rode Podcaster),0x00200000,0,0,qcap.dll,6.06.7601.17514
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,6.06.7601.17528
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.06.7601.17713
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,6.06.7601.17713
WDM Streaming Capture Devices:
SigmaTel Audio,0x00200000,3,2,ksproxy.ax,6.01.7601.17514
HD Pro Webcam C910,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Logitech HD Pro Webcam C910,0x00200000,2,2,ksproxy.ax,6.01.7601.17514
QuickCam for Dell Notebooks,0x00200000,0,2,ksproxy.ax,6.01.7601.17514
Rode Podcaster,0x00200000,3,2,ksproxy.ax,6.01.7601.17514
WDM Streaming Rendering Devices:
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.7601.17514
Video Capture Sources:
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.7601.17669
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.7601.17514
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,1,EncDec.dll,6.06.7601.17708
Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.7601.17708
PTFilter,0x00200000,0,0,EncDec.dll,6.06.7601.17708
XDS Codec,0x00200000,0,0,EncDec.dll,6.06.7601.17708
WDM Streaming Communication Transforms:
Audio Renderers:
Speakers (SigmaTel High Definit,0x00200000,1,0,quartz.dll,6.06.7601.17713
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.06.7601.17713
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.06.7601.17713
DirectSound: Speakers (Rode Podcaster),0x00200000,1,0,quartz.dll,6.06.7601.17713
DirectSound: Speakers (SigmaTel High Definition Audio CODEC),0x00200000,1,0,quartz.dll,6.06.7601.17713
EVR Power Information
Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
Quality Flags: 2576
Enabled:
Force throttling
Allow half deinterlace
Allow scaling
Decode Power Usage: 100
Balanced Flags: 1424
Enabled:
Force throttling
Allow batching
Force half deinterlace
Force scaling
Decode Power Usage: 50
PowerFlags: 1424
Enabled:
Force throttling
Allow batching
Force scaling
Decode Power Usage: 0
System Information
Memory: 4096MB RAM
DxDiag Notes
Display Devices
Monitor Id: LPL3D00
DDI Version: 9Ex
WHQL Logo'd: Yes
WHQL Date Stamp:
Vendor ID: 0x1002
Device ID: 0x7102
Revision ID: 0x0000
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: Yes
Other Files:
Cap Flags: 0xF1F
HW Memory: 0
Product ID: 65535
Type: WDM
WHQL Logo'd: Yes
Other Files:
Cap Flags: 0xF1F
HW Memory: 0
Cap Flags: 0x1
Cap Flags: 0x1
Cap Flags: 0x1
Cap Flags: 0x1
Cap Flags: 0x1
Cap Flags: 0x1
Cap Flags: 0x1
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
FF Driver: n/a
Attached: 1
Controller ID: n/a
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: ART
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
USB Devices
+ USB Root Hub
| Service: usbhub
| | Service: HidUsb
Gameport Devices
PS/2 Devices
| Service: i8042prt
| Service: kbdhid
| Service: kbdhid
| Service: kbdhid
| Service: kbdhid
| Service: TermDD
| Service: mouhid
| Service: mouhid
| Service: mouhid
| Service: TermDD
Drive: C:
File System: NTFS
Drive: D:
System Devices
Driver: n/a
Driver: n/a
Driver: n/a
DirectShow Filters
DirectShow Filters:
Video Compressors:
Audio Compressors:
PBDA CP Filters:
Midi Renderers:
BDA CP/CA Filters:
Audio Renderers:
Quality Flags: 2576
Enabled:
Force throttling
Allow scaling
Enabled:
Force throttling
Allow batching
Force scaling
PowerFlags: 1424
Enabled:
Force throttling
Allow batching
Force scaling
Blank screen problem is usually a problem with a video driver, but check it in the console.
If you see javax.xxx.opengl.xxx errors that's it.
I've been struggling with it for a couple of days now and finally sorted it out.
I have an win 8.1 64bit notebook (few years old) with an ATI Mobility Radeon HD 3430 video card.
The problem seems to be with the ATI cards with Microsoft drivers for them.
I also used GPU Caps Viwer, which crashed, and GPU-Z which alerted me that I have a buggy driver.
What helped was:
1) Uninstall all the ATI drivers (and Catalyst)
2) Install the latest drivers for the card (which didn't help at all in this step, but was necessary)
3) In the Device Manager uninstall the display adapter driver, with the option to delete the driver file (which will switch in VGA mode, don't panic)
4) Restart windows
5) On startup, windows will install the correct driver from step 2
6) And finally launch HELI-X 5 and the black screen should be gone
Hope this helps anyone with the same problem.
Igor
What helped was:
4) Restart windows
Igor
