5 channel mode / Throttle problems?
Posted: 03 Feb 2014 21:22
by chiruchi
I'm running Heli-X v5 on OSX Maverics with FrSky Taranis controller and a chinese combo USB adapter + cord combination.
It works like a charm in my iMac, but I'm having troubles running the very same Heli-X and other combo on my MacBook Pro. I can get basically everything else working, but can't get the throttle to work in the simulator. I noticed that in the iMac I can check the 5 channels option and can also assign "Throttle" as one of the sticks, other than just x,y,z and slider.
Any suggestions on what do try? Can I edit some files manually to enable this?
Thanks for the support :shock:
Re: 5 channel mode / Throttle problems?
Posted: 03 Feb 2014 21:37
by chiruchi
...Nevermind. For some reason I had to switch the mode from my USB controller to AeroXcraft even though it worked as it is on my iMac. Perhaps it's an issue when you set it up once and it can be something else later on. I dunno but now I got more channels visible this way. And it works.
And I feel a bit more stupid :lol: :roll:
Posted: 03 Feb 2014 23:22
by ThomasC
chiruchi wrote: And I feel a bit more stupid :lol: :roll:
You might call it "a bit more experienced" instead ;)
