Proper Cable for Mac OSX und DX6
BegiNner84
Post by BegiNner84 »
Hi all,
I´m quite new here and started first flights with a ESKY Transmitter.
I just got my SPEKTRUM DX6 and wanted to connect my DX6 with this cable set:
http://www.amazon.de/gp/product/B00H0G9 ... _ttl_sol_0
I´m a bit confused because I´m only able to set axis: x,y,z and the slider, but no function on tail.
Support of the company, who sells this cable set already sent me a new cable set, because say it should
be working - but the new cable doesn´t work, too.
Anybody here that uses this cable with a DX6 or has similar issues?
Maybe I have to change some setups on my DX6?
Kind regards
Re: Proper Cable for Mac OSX und DX6
On MAc OS-X things are sometimes a bit complicated:
Search for the file jinput.jar in the HELI-X folder on your Mac. There are three versions. Try the others, that might help.
BegiNner84
Thanks, but I need a little bit more detail information.
I found the file and the 3 other ones, but how can I try the other versions? What should I do next?
BegiNner84
I just tried to rename the other versions into input.jar - prior version b-8 works!! Thanks a lot!
