Kein Programmstart bei Ubuntu 15.04
Gimli
Post by Gimli »
ich habe die Dateien in das "home" Verzeichnis entpackt.
Nach einem Doppelklick auf die Datei "runHELI-X.sh" startet gedit mit folgender Ausgabe:
#!/bin/bash
cd $( dirname $0 )
PWD=.
if [ -e "$PWD/libs/HeliX/HeliX6_new.jar" ]
then
if [ -e "$PWD/libs/HeliX/HeliX6_back.jar" ]
then
rm "$PWD/libs/HeliX/HeliX6_back.jar"
fi
cp "$PWD/libs/HeliX/HeliX6.jar" "$PWD/libs/HeliX/HeliX6_back.jar"
mv "$PWD/libs/HeliX/HeliX6_new.jar" "$PWD/libs/HeliX/HeliX6.jar"
fi
JINPUT="jinput.jar"
if [ -e "$PWD"/files/Application/inputsystem ]
then
JINPUT=`cat "$PWD"/files/Application/inputsystem`
fi
LIBPATH="$PWD/libs/"
LIBS="$PWD/"
JARPATH="$PWD/libs"
CP="$CP:$JARPATH/HeliX/HeliX6.jar"
CP="$CP:$JARPATH/HeliX/Translation.jar"
CP="$CP:$JARPATH/HeliX/Media.jar"
CP="$CP:$JARPATH/jme/jME3-core.jar"
CP="$CP:$JARPATH/jme/jME3-plugins.jar"
CP="$CP:$JARPATH/jme/jME3-desktop.jar"
CP="$CP:$JARPATH/jme/jME3-terrain.jar"
CP="$CP:$JARPATH/jme/jME3-blender.jar"
CP="$CP:$JARPATH/jme/jME3-jogg.jar"
CP="$CP:$JARPATH/jme/jME3-lwjgl.jar"
CP="$CP:$JARPATH/jme/jME3-effects.jar"
CP="$CP:$JARPATH/jme/eventbus.jar"
CP="$CP:$JARPATH/jme/lwjgl.jar"
CP="$CP:$JARPATH/jme/nifty.jar"
CP="$CP:$JARPATH/jme/jME3-niftygui.jar"
CP="$CP:$JARPATH/jme/xmlpull-xpp3.jar"
CP="$CP:$JARPATH/jme/joal.jar"
CP="$CP:$JARPATH/jme/$JINPUT"
CP="$CP:$JARPATH/jdom/jdom.jar"
CP="$CP:$JARPATH/javagamenetworking/jgn.jar"
CP="$CP:$JARPATH/math/openmali.jar"
CP="$CP:$JARPATH/jme/gluegen-rt.jar"
CP="$CP:$JARPATH/jme/j-ogg-oggd.jar"
CP="$CP:$JARPATH/jme/j-ogg-vorbisd.jar"
CP="$CP:$JARPATH/jme/styles.zip"
CP="$CP:$JARPATH/jme/nifty-default-controls.jar"
CP="$CP:$JARPATH/jme/nifty-style-black.jar"
java -Xms512m -Xmx1024m -Djava.library.path="$LIBS" -classpath "$CP" HELIX
# If you want to set the proxy settings manually, use this:
# java -Xms512m -Dhttp.proxyHost=<PROXY_NAME_OR_IP> -Dhttp.proxyPort=<PROXY_PORT> -Djava.library.path="$LIBS" -classpath "$CP" HELIX
Und dann passiert nichts mehr ...
Habe zuvor Java mit "sudo apt-get install default-jre" installiert
Wo könnte der Fehler liegen?
Danke
Jörg
Re: Kein Programmstart bei Ubuntu 15.04
Starte aus einer Konsole mit
./runHELI-X.sh
Gimli
Post by Gimli »
Danke, Michael!
So funktioniert der Programmstart.
Gibt es jetzt eine Möglichkeit, dies für die Zukunft komfortabler zu gestalten?
- bin leider nicht so der Linux / Ubuntu Experte :(
Gimli
Post by Gimli »
Jetzt funktioniert's :D
Habe in "nautilus" bei Einstellungen das Verhalten von Dateien auf "Ausführbare Textdateien ausführen, wenn sie geöffnet werden" geändert.
Wieder etwas gelernt :D
Danke nochmal, Michael für den entsprechenden Hinweis
