HELI-X 6 Startet nicht korrekt
clel
Post by clel »
Wenn ich HELI-X 6 auf Windows starte, erscheint die Sprachauswahl und nachdem ich deutsch ausgewählt habe, lädt das Programm. Wenn der Ladebalken aber am Ende ist, verschwindet das Fenster und in der Konsole erscheint eine Fehlermeldung. Der komplette Text in der Konsole lautet:
C:\Program Files (x86)\HELI-X6>if exist .\libs\HeliX\HeliX6_new.jar (
if exist .\libs\HeliX\HeliX6_back.jar (del .\libs\HeliX\HeliX6_back.jar )
 copy .\libs\HeliX\HeliX6.jar .\libs\HeliX\HeliX6_back.jar
 del .\libs\HeliX\HeliX6.jar
 rename .\libs\HeliX\HeliX6_new.jar HeliX6.jar
C:\Program Files (x86)\HELI-X6>set libPath=.
C:\Program Files (x86)\HELI-X6>set jars=./libs/HeliX/HeliX6.jar
C:\Program Files (x86)\HELI-X6>set jars=./libs/HeliX/HeliX6.jar;./libs/HeliX/Tra
nslation.jar
nslation.jar;./libs/HeliX/Media.jar
nslation.jar;./libs/HeliX/Media.jar;./libs/jme/jME3-core.jar
nslation.jar;./libs/HeliX/Media.jar;./libs/jme/jME3-core.jar;./libs/jme/jME3-plu
gins.jar
gins.jar;./libs/jme/jME3-terrain.jar
gins.jar;./libs/jme/jME3-terrain.jar;./libs/jme/jME3-desktop.jar
gins.jar;./libs/jme/jME3-terrain.jar;./libs/jme/jME3-desktop.jar;./libs/jme/jME3
-blender.jar
-blender.jar;./libs/jme/jME3-jogg.jar
-blender.jar;./libs/jme/jME3-jogg.jar;./libs/jme/jME3-lwjgl.jar
-blender.jar;./libs/jme/jME3-jogg.jar;./libs/jme/jME3-lwjgl.jar;./libs/jme/jME3-
effects.jar
effects.jar;./libs/jme/eventbus.jar
effects.jar;./libs/jme/eventbus.jar;./libs/jme/lwjgl.jar
effects.jar;./libs/jme/eventbus.jar;./libs/jme/lwjgl.jar;./libs/jme/nifty.jar
effects.jar;./libs/jme/eventbus.jar;./libs/jme/lwjgl.jar;./libs/jme/nifty.jar;./
libs/jme/jME3-niftygui.jar
libs/jme/jME3-niftygui.jar;./libs/jme/xmlpull-xpp3.jar
libs/jme/jME3-niftygui.jar;./libs/jme/xmlpull-xpp3.jar;./libs/jme/joal.jar
C:\Program Files (x86)\HELI-X6>set tempinput=jinput.jar
C:\Program Files (x86)\HELI-X6>if exist .\files\Application\inputsystem (set /p
tempinput= 0<.\files\Application\inputsystem )
libs/jme/jME3-niftygui.jar;./libs/jme/xmlpull-xpp3.jar;./libs/jme/joal.jar;./lib
s/jme/jinput.jar
s/jme/jinput.jar;./libs/jdom/jdom.jar
s/jme/jinput.jar;./libs/jdom/jdom.jar;./libs/javagamenetworking/jgn.jar
s/jme/jinput.jar;./libs/jdom/jdom.jar;./libs/javagamenetworking/jgn.jar;./libs/m
ath/openmali.jar
ath/openmali.jar;./libs/jme/gluegen-rt.jar
ath/openmali.jar;./libs/jme/gluegen-rt.jar;./libs/jme/j-ogg-oggd.jar
ath/openmali.jar;./libs/jme/gluegen-rt.jar;./libs/jme/j-ogg-oggd.jar;./libs/jme/
j-ogg-vorbisd.jar
j-ogg-vorbisd.jar;./libs/jme/styles.zip
j-ogg-vorbisd.jar;./libs/jme/styles.zip;./libs/jme/nifty-default-controls.jar
j-ogg-vorbisd.jar;./libs/jme/styles.zip;./libs/jme/nifty-default-controls.jar;./
libs/jme/nifty-style-black.jar
C:\Program Files (x86)\HELI-X6>Java\jre8\bin\java.exe -Djava.library.path=. -Xms
512m  -classpath ./libs/HeliX/HeliX6.jar;./libs/HeliX/Translation.jar;./libs/Hel
iX/Media.jar;./libs/jme/jME3-core.jar;./libs/jme/jME3-plugins.jar;./libs/jme/jME
3-terrain.jar;./libs/jme/jME3-desktop.jar;./libs/jme/jME3-blender.jar;./libs/jme
/jME3-jogg.jar;./libs/jme/jME3-lwjgl.jar;./libs/jme/jME3-effects.jar;./libs/jme/
eventbus.jar;./libs/jme/lwjgl.jar;./libs/jme/nifty.jar;./libs/jme/jME3-niftygui.
jar;./libs/jme/xmlpull-xpp3.jar;./libs/jme/joal.jar;./libs/jme/jinput.jar;./libs
/jdom/jdom.jar;./libs/javagamenetworking/jgn.jar;./libs/math/openmali.jar;./libs
/jme/gluegen-rt.jar;./libs/jme/j-ogg-oggd.jar;./libs/jme/j-ogg-vorbisd.jar;./lib
s/jme/styles.zip;./libs/jme/nifty-default-controls.jar;./libs/jme/nifty-style-bl
ack.jar HELIX
Exception in thread "LWJGL Renderer Thread" java.lang.UnsatisfiedLinkError: Can'
t load library: C:\Users\Claudius\.jme3\natives_bdd2c34\lwjgl.dll
        at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1825)
        at java.lang.Runtime.load0(Runtime.java:809)
        at java.lang.System.load(System.java:1083)
        at org.lwjgl.Sys$1.run(Sys.java:70)
        at org.lwjgl.Sys.doLoadLibrary(Sys.java:66)
        at org.lwjgl.Sys.loadLibrary(Sys.java:95)
        at org.lwjgl.Sys.<clinit>(Sys.java:112)
        at com.jme3.system.lwjgl.LwjglAbstractDisplay.run(LwjglAbstractDisplay.j
ava:206)
Re: HELI-X 6 Startet nicht korrekt
Bitte installiere erst mal wie vorgeschlagen unter c:\HELI-X6
clel
Post by clel »
Das klappt, danke! Wollte ich eigentlich noch probieren, hatte es dann aber vergessen. Wird man HELI-X denn in Zukunft auch woanders installieren können (am besten im Programm Ordner von Windows)?
..man muss dann auch die passenden Schreibrechte setzen, das einige Bibliotheken lokal entpackt werden.
@clel: sollte kein Thema sein, solange Du keine Sonderzeichen (Umlaute bedingt durch eigenen Namen z.B.) im Pfad hast. Bei mir läuft es z.B. problemlos aus K:\Programme\HELI-X6\
clel
Post by clel »
Ich hatte es, als es nicht funktioniert hat, im Ordner C:\Program Files\HELI-X6\ installiert. Möglicherweise macht das Leerzeichen Probleme? Oder es liegt wirklich an den Schreibrechten. Der Java Fehler ist ja auch, dass es irgendeine Datei nicht öffnen kann. Kann man die Installation von HELI-X so anpassen, dass sie die Schreibrechte beim Installieren automatisch setzt (und standardmäßig wie andere Programme in den Programmordner installiert)? Dann hätte man das Programm im Standard Programm Ordner von Windows installiert.
Ansonsten wäre auch gerne erst einmal als Workaround gut zu wissen, welche Rechte man manuell wie setzen muss.
