Changing Startup Defaults
skycyclepilot
Post by skycyclepilot »
Is there any way to change some of the startup defaults - perhaps by editing XML files?
The startup position of the heli is too close to the pilot for hover training. Once I start Heli-X, the first thing I do is move the heli a few feet away, and then use the "Set new start position" shortcut. However, Heli-X does not remember this new position once I exit the program.
I'd also like for the program to start in Full Screen mode.
Minor stuff, I know...
Re: Changing Startup Defaults
the start position of the helicopter is a property of the airport. You can change it permanently in the xml file of the airport.
It is currently not possible to set the full screen mode as default.
Have a nice christmas.
