HELI-X7 wont start
gmkramer
HELI-X7 wont start
Post by gmkramer »
Just downloaded Version X7 and when I try to load it, I immediately get the message:
The module "msxml4.dll" failed to load.
Make sure the binary is stored at the specified path or debut it to check for problems with the binary or dependent .DLL files.
A dynamic link library (DLL) initialization routine failed.
Any ideas as to how to fix this problem?
Re: HELI-X7 wont start
Strange. I found this web site where this problem is discussed:
https://www.lifewire.com/how-to-fix-msx ... rs-2623824
Did you have this problem also with an earlier version of HELI-X?
gmkramer
Post by gmkramer »
I scanned my laptop and found no problems. I uninstalled both X6 and x7 and reinstalled X7 and get the following error message when I try to start the program:
Unable to execute file c:\heli-x7\run heli-x.bat
Shell ExecuteEx failed code -2147467262.
No such interface supported.
cbarbu
Post by cbarbu »
Can you try to start as an administrator („run as“)? does it work then?
gmkramer
Post by gmkramer »
it wont allow me to run as admin
gmkramer
Post by gmkramer »
Can anyone help? I reinstalled Version 6 and I have the same problems.
gmkramer
Post by gmkramer »
I found that if I go to the command prompt in c:\heli-x7 and type .\runheli-x the program works.
How can I change the bat file or any other files so I dont have to go to the command prompt every time I want to run the program?
Perhaps look at the porperties (right mouse button) of the start icon. There is also a security tab ...
cbarbu
Post by cbarbu »
I think it's a permissions problem (missing access rights).
Confusing that works in command box. This means that the installation and the batch file (runHELI-X.bat) is ok.
Only the link from Desktop (HELI-X7) can not be executed. Bad link, no access rights to run file, why not?
Please rename the original link (HELI-X7) on the desktop (maybe to HELI-X7 BAD). Make a COPY of the batch file (C: \ HELI-X7 \ runHELI-X.bat) on the desktop. Start this COPY now. Is working?
If that works, create a LINK from batch file (C: \ HELI-X7 \ runHELI-X.bat) to the desktop. Start the LINK now. Is working?
gmkramer
Post by gmkramer »
Neither of these last 2 suggestions worked. Now, when I do get the program to load, it recognizes that I have a controller attached but moving the sticks does nothing (yes, I tried to calibrate it but that doesnt work)
