UnsupportedClassVersionError with Heli-X 7 on Debian
driftbeater
Post by driftbeater »
i'm running Debian jessie and just downloaded Heli-X 7.
When trying to start it i immediately get an exception:
:~/HELI-X7$ ./runHELI-X.sh
Exception in thread "main" java.lang.UnsupportedClassVersionError: HELIX : Unsupported major.minor version 52.0
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:803)
at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:142)
at java.net.URLClassLoader.defineClass(URLClassLoader.java:442)
at java.net.URLClassLoader.access$100(URLClassLoader.java:64)
at java.net.URLClassLoader$1.run(URLClassLoader.java:354)
at java.net.URLClassLoader$1.run(URLClassLoader.java:348)
at java.net.URLClassLoader.findClass(URLClassLoader.java:347)
at java.lang.ClassLoader.loadClass(ClassLoader.java:425)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:312)
at java.lang.ClassLoader.loadClass(ClassLoader.java:358)
at sun.launcher.LauncherHelper.checkAndLoadMain(LauncherHelper.java:482)
Any ideas? :?
Re: UnsupportedClassVersionError with Heli-X 7 on Debian
Hm,
which Java version do you use?
driftbeater
java version "1.7.0_131"
OpenJDK Runtime Environment (IcedTea 2.6.9) (7u131-2.6.9-2~deb8u1)
OpenJDK 64-Bit Server VM (build 24.131-b00, mixed mode)
driftbeater
Problem solved. I upgraded from Debian jessie to stretch. Everything works fine now :D
Godd to hear.
Thanks
