Rev 2432
Rev 2432
New in 2432:
- Graphics bug in flight mode window after switch to fullscreen is solved.
- New default values: 200 FPS.
Have fun and thank you for your feedback.
lama12
Re: Rev 2432
Post by lama12 »
found one inconsistency:
the scene selection window does not remember the last scene selected in contract to the model and airport selection windows that do remember the last selected model or airport.
Also, it would make sense to be able to select the desired resolution in the scene selection window, which by default would be the same as the last selected resolution for airport or scene.
cheers, Matthijs
lama12
Re: Rev 2432
Post by lama12 »
Personally I prefer to fly with wind on.
Request: Can Heli-X V10 remember the "set wind active" setting between closing and starting Heli-X ?
thx Matthijs
Re: Rev 2432
This is a feature. We had the feeling that - when e.g. in multiplayer mode the wind was set to on - the user might be confused when the wind comes back after the next start.
Thus, I would prefer to let it so at the moment.
Thanks.
