Marsdorf location
jinxjx
Marsdorf location
Post by jinxjx »
hi, is there something wrong with this location ? when i open this airport, it opens but then closes to desktop. all the others are fine.....also with schneeszenerie airport the heli starts/sits 4ft off the ground.......thanks.... :shock:
jinxjx
Re: Marsdorf location
Post by jinxjx »
nevermind !!, i deleted these two junk airports !!!! all good now
I will check this ...
I double checked the Marsdorf airport. I cannot see a problem in Version 10. Please reinstall the airport and try again.
... and there was a mistake in Schneeszenerie. Please update from the server.
Thanks!
jinxjx
Post by jinxjx »
I redownloaded Marsdorf airport and all good now, i must have had a corrupted file or something. Thanks for fixing Schneeszenerie ....thank you :D
jinxjx
Post by jinxjx »
ok, going to fullscreen mode crashes to desktop on marsdorf and certain helis. in windows mode its fine. im running 34" 16:9 ultrawide 3440 x 1440. i have fps enabled and in windows mode its locked at 164 fps. all my other sims/games are fine in fullscreen......thanlk you
