Mikado Vbar evo keeps disconnecting from wifi
Radek
Post by Radek »
Hi guys, i having a problem with disconnecting my vbar evo controller when on wifi. Let me just say wright from the start that i don't thing it it an issue with the sim. From the beginning everything has been flawless until recently. It's either my laptop Dell XPS 15 (2018) or my router. So my question is what setting i should check. Router is netgear but bit older so no update avaible for some time. After while the computer completely disconnects from the network and reconnects or have to run troubleshoot. Is it important in which order are appliances connected to the network? Opening the sim and them connecting the vbar control?
Thank you for any help. R
admin
Administrator
Re: Mikado Vbar evo keeps disconnecting from wifi
Post by admin »
In V10, restrict the frame rate to 200 or less when using the VBAR via WLAN
Radek
Post by Radek »
admin wrote: 30 Mar 2025 20:29 In V10, restrict the frame rate to 200 or less when using the VBAR via WLAN
Will try. Thank you for the tip.
