Controller Detected Pop Up
Posted: 12 Jun 2025 03:43
by Nalizan
Hello everyone. I am new to the sim but loving it so far. I started having a problem with it and wondered if someone else has seen this before or can offer a suggestion.
I am using the Mikado Evo + transmitter with WiFi. This worked great the first day. I went through the setup and flew without issues. The last few times I have run the sim though I have been plagued with pop ups that appear every few mins stating that a controller was detected.
I tried deleting the transmitter setup and running it again but I continue to see these messages. It pauses the sim each time it happens so its very disruptive. I do have a PS5 controller plugged into my computer at times (wired), but I have ensured that it was disconnected the last two sessions and I still get the message popping up. Any idea what the cause is or how I can get it to stop?
Thanks so much!
Re: Controller Detected Pop Up
Posted: 12 Jun 2025 07:32
by admin
Are you using V11? There the problem dhould be solved. if not:
How many FPS do you have? Try to limit the FPS in the global settings, e.g. to FPS 200
Posted: 13 Jun 2025 02:12
by Nalizan
I am on V11. I set the max frame rate to 200FPS and that seems to have fixed it. Thanks!
