Demo Heli x locks up when controller selected
Hi, Just downloaded the demo to see how it works. I have a futaba usb interlink controller and when I scan for controller it selects i-controller. When I select ok everything locks up. If I unplug the controller the program closes. When started again it just locks up again. Without the controller pluged in the program will start but when rescan controllers is selected it does nothing. Is there anyway to use this controller with Heli-x?
Re: Demo Heli x locks up when controller selected
This shold work
Is this version 11?
Please start HELI-X with controller pluged in, and open the terminal window in HELI-X and show the contents.
Is this version 11?
Yes 11 demo
When selected controller it locked again this is on the terminal
e:\ProgramData\HELI-X11>"e:\Program Files\HELI-X11\Java\jre21\bin\HELI-X.exe" --add-opens java.base/sun.nio.ch=ALL-UNNAMED -XX:+UseParallelGC -Xms1g -Xmx4g -XX:MaxGCPauseMillis=200 -XX:ParallelGCThreads=20 -XX:ConcGCThreads=5 -XX:InitiatingHeapOccupancyPercent=70 -Djdk.tls.client.protocols=TLSv1.2 -Djava.library.path="e:\ProgramData\HELI-X11" -DheliX.path.resources="e:\ProgramData\HELI-X11\resources" -DheliX.path.files="e:\ProgramData\HELI-X11\files" -DheliX.path.java="e:\Program Files\HELI-X11\Java\jre21\bin" -classpath ./libs/HeliX/HeliX11.jar;./libs/HeliX/HeliX_VR.jar;./libs/HeliX/Translation.jar;./libs/HeliX/Media.jar;./libs/jme/jme3-core.jar;./libs/jme/jme3-plugins.jar;./libs/jme/jme3-plugins-json.jar;./libs/jme/jme3-terrain.jar;./libs/jme/jme3-desktop.jar;./libs/jme/jme3-jogg.jar;./libs/jme/jme3-lwjgl3.jar;./libs/jme/jme3-effects.jar;./libs/jme/lwjgl.jar;./libs/jme/lwjgl-glfw.jar;./libs/jme/lwjgl-opengl.jar;./libs/jme/lwjgl-jemalloc.jar;./libs/jme/lwjgl-openal.jar;./libs/jme/lwjgl-openvr.jar;./libs/jme/nifty.jar;./libs/jme/jme3-niftygui.jar;./libs/jme/xpp3.jar;./libs/jme/jutils.jar;./libs/jdom/jdom.jar;./libs/javagamenetworking/jgn.jar;./libs/javagamenetworking/slf4j-api-2.0.16.jar;./libs/javagamenetworking/slf4j-simple-2.0.16.jar;./libs/javagamenetworking/commons-collections4-4.4.jar;./libs/math/openmali.jar;./libs/jme/j-ogg-vorbis.jar;./libs/jme/gson.jar;./libs/jme/styles.zip;./libs/jme/nifty-default-controls.jar;./libs/jSerial/jSerialComm-2.4.0.jar HELIX
SEVERE Element 6:45:00?PM Index is out of range. Index: 4 Last valid: 3
java.lang.NullPointerException: Cannot invoke "java.lang.Integer.intValue()" because the return value of "java.util.HashMap.get(Object)" is null
at net.HeliX.h.u.onJoyAxisEvent(Unknown Source)
at com.jme3.input.InputManager.processQueue(InputManager.java:849)
at com.jme3.input.InputManager.update(InputManager.java:923)
at com.jme3.app.LegacyApplication.update(LegacyApplication.java:805)
at net.HeliX.x.i.update(Unknown Source)
at net.HeliX.x.o.update(Unknown Source)
at com.jme3.system.lwjgl.LwjglWindow.runLoop(LwjglWindow.java:629)
at com.jme3.system.lwjgl.LwjglWindow.run(LwjglWindow.java:719)
at java.base/java.lang.Thread.run(Unknown Source)
Well guess that means won't be buying Heli-x if no one can figure it out.
