and some other guy with a problem I found on this forum but unfortunately no working solution for me yet ...
I got myself the USB 6ch Simulator by Dynam and connected it directly to an USB port on my MacPro.
it is recognized and shows in the System-Profiler as "PPM":
Produkt-ID: 0x0003
Hersteller-ID: 0x06f7
Version: 1.07
Geschwindigkeit: Bis zu 1,5 MBit/s
Hersteller: WAILLY
Standort-ID: 0x1d200000
Verfügbare Stromstärke (mA): 500
Erforderliche Stromstärke (mA): 500Code: Select all
Button #1 : Minimum = 0, Default = 0, Maximum = 0
Button #2 : Minimum = 0, Default = 0, Maximum = 0
Button #3 : Minimum = 0, Default = 0, Maximum = 0
Button #4 : Minimum = 0, Default = 0, Maximum = 0
Button #5 : Minimum = 0, Default = 0, Maximum = 0
Button #6 : Minimum = 0, Default = 0, Maximum = 0
Button #7 : Minimum = 0, Default = 0, Maximum = 0
Button #8 : Minimum = 0, Default = 0, Maximum = 0
Button #9 : Minimum = 0, Default = 0, Maximum = 0
Button #10 : Minimum = 0, Default = 0, Maximum = 0
Button #11 : Minimum = 0, Default = 0, Maximum = 0
Button #12 : Minimum = 0, Default = 0, Maximum = 0
Z-Axis : Minimum = 0, Default = 0, Maximum = 0
Z-Rotation : Minimum = 0, Default = 0, Maximum = 0
X-Axis : Minimum = 0, Default = 0, Maximum = 0
Y-Axis : Minimum = 0, Default = 0, Maximum = 0
X-Rotation : Minimum = 0, Default = 0, Maximum = 0
Y-Rotation : Minimum = 0, Default = 0, Maximum = 0
Hatswitch : Minimum = 0, Default = 0, Maximum = 0Code: Select all
<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
<key>device type</key>
<string>gaming</string>
<key>hid descriptor</key>
<data>
BQEJBKEBoQJ1CJUGFQAm/wA1gEZ/AAkyCTUJMAkxCTMJNIECdQSVASUHRjsBZRQJOYFC
ZQB1AZUMJQFFAQUJGQEpDIECwMA=
</data>
<key>hid usage</key>
<integer>4</integer>
<key>hid usage page</key>
<integer>1</integer>
<key>interface number</key>
<integer>0</integer>
<key>location id</key>
<integer>488636416</integer>
<key>product id</key>
<integer>3</integer>
<key>product name</key>
<string>PPM</string>
<key>product version</key>
<integer>263</integer>
<key>readable inputs</key>
<integer>19</integer>
<key>transport</key>
<key>vendor id</key>
<integer>1783</integer>
<key>vendor id source</key>
<key>vendor name</key>
<string>WAILLY</string>
</dict>
</plist>but in the configuration set-up window the bars want move while using the device ...
summarizing
-> USB 6ch Simulator by Dynam is recognized by the System and has enough power to work correctly.
-> USB Overdrive does recognize it too and shows all movements of the device.
-> Heli-X recognizes the device, but doesn't let me configure it?!
does anybody have an idea what the problem is and could give me a solution to make my USB controller work in Heli-X?
BIG thanks in advance for any helpful input!
