0 FPS Bei Aktivierung der Vollversion
Posted: 01 Jan 2012 16:50
by Quirl
Hallo ich habe folgendes Problem sobald ich meine version aktiviere geht gar nichts mehr 0fps ich hänge mal an was java ausspuckt ich hoffe jemand kann mir helfen ich bin am ende.
Zumal alles vor der Neuinstallation von win xp sp3 alles lief.
lenovo G550
F:\HELI-X30>set system=windows-i586
F:\HELI-X30>set libPath=./libs
F:\HELI-X30>set libPath=./libs;./libs/gluegen/windows-i586
F:\HELI-X30>set libPath=./libs;./libs/gluegen/windows-i586;./libs/jinput/windows
-i586
-i586;./libs/jogl/windows-i586
-i586;./libs/jogl/windows-i586;./libs/lwjgl/windows-i586
-i586;./libs/jogl/windows-i586;./libs/lwjgl/windows-i586;./libs/joal/windows-i58
6
F:\HELI-X30>set jars=./libs/HeliX/HeliX.jar
F:\HELI-X30>set jars=./libs/HeliX/HeliX.jar;./libs/gluegen/gluegen-rt.jar
F:\HELI-X30>set jars=./libs/HeliX/HeliX.jar;./libs/gluegen/gluegen-rt.jar;./libs
/jagatoo/jagatoo.jar
/jagatoo/jagatoo.jar;./libs/javagamenetworking/jgn.jar
/jagatoo/jagatoo.jar;./libs/javagamenetworking/jgn.jar;./libs/jdom/jdom.jar
/jagatoo/jagatoo.jar;./libs/javagamenetworking/jgn.jar;./libs/jdom/jdom.jar;./li
bs/joal/joal.jar
bs/joal/joal.jar;./libs/jogl/jogl.jar
bs/joal/joal.jar;./libs/jogl/jogl.jar;./libs/lwjgl/lwjgl.jar
bs/joal/joal.jar;./libs/jogl/jogl.jar;./libs/lwjgl/lwjgl.jar;./libs/jinput/Jinpu
t.jar
t.jar;./libs/math/openmali.jar
t.jar;./libs/math/openmali.jar;./libs/xith/xith3d.jar
t.jar;./libs/math/openmali.jar;./libs/xith/xith3d.jar;./libs/xith/hud-themes.jar
;./libs/sound/jogg-0.0.7.jar
;./libs/sound/jogg-0.0.7.jar;./libs/sound/jorbis-0.0.15.jar
;./libs/sound/jogg-0.0.7.jar;./libs/sound/jorbis-0.0.15.jar;./libs/sound/tritonu
s_share.jar
F:\HELI-X30>Java\jre6\bin\java.exe -Dsun.java2d.noddraw=true -Djava.library.path
=./libs;./libs/gluegen/windows-i586;./libs/jinput/windows-i586;./libs/jogl/windo
ws-i586;./libs/lwjgl/windows-i586;./libs/joal/windows-i586 -Xmx384m -classpath
./libs/HeliX/HeliX.jar;./libs/gluegen/gluegen-rt.jar;./libs/jagatoo/jagatoo.jar;
./libs/javagamenetworking/jgn.jar;./libs/jdom/jdom.jar;./libs/joal/joal.jar;./li
bs/jogl/jogl.jar;./libs/lwjgl/lwjgl.jar;./libs/jinput/Jinput.jar;./libs/math/ope
nmali.jar;./libs/xith/xith3d.jar;./libs/xith/hud-themes.jar;./libs/sound/jogg-0.
0.7.jar;./libs/sound/jorbis-0.0.15.jar;./libs/sound/tritonus_share.jar HELIX
Set new path for the resources: F:/HELI-X30/resources/
Set new path for the user files: F:/HELI-X30/files/
Couldn't find tag "Resolution" in file "F:/HELI-X30/files/Application/ViewSettin
gs.xml"
Using openGLLayer JOGL_AWT
Found 234 display modes
Controller found: Name: PPM(PPM)
Using Stick PPM
Controller configuration file found: F:/HELI-X30/files/controller/PPM.xml
Controller configuration file F:/HELI-X30/files/controller/PPM.xml read
Re: 0 FPS Bei Aktivierung der Vollversion
Posted: 01 Jan 2012 17:40
... Du hast auch ein Win-Update gemacht? Dann sind wohl die Grafiktreiber noch zu aktualisieren.
Wenn es nicht hilft: Die Anti-Aliasing-Einsetllungen unter Einstellungen->Leistung überprüfen.
Posted: 01 Jan 2012 18:00
by Quirl
die demoversion lüft ja einwandfrei dann kann es doch an meinem klapprechner nicht liegen oder, sobald ich jedoch den Schlüssel eingebe geht nix mehr also fps und das ist
der gleiche treiber wie bei der vorherigen installation weil ich dafür auf die lenovo seite gehe.
Posted: 01 Jan 2012 18:05
Ah, dann bitte sicherstellen, dass wirklich ein Airport vom Typ 1024 ausgewält ist. Wenn es nicht geht, bitt Airprt Small testen ...
Posted: 01 Jan 2012 20:40
by Quirl
Airport 1024 genau das war es da war der hund bei mir begraben ich bedanke mich vielmals für diese kompetente Hilfestellung.
Ich wünsche ein frohes und gesundes Jahr 2012
