after selecting the heli, the system shuts down.
Posted: 01 Oct 2008 23:06
Hello all,
Since my german insn't all that good, ill do this in english..
After starting Heli-X, i select a lanscape, then a helicopter.
5 seconds after loading the heli, the program quits.
It makes a log file, stated below.
Can any1 help me out?
It runs on a brandnew Dell laptop, specs also stated below.
Thanx!
# An unexpected error has been detected by Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x2705f9d0, pid=2428, tid=3936
# Java VM: Java HotSpot(TM) Client VM (1.6.0_03-b05 mixed mode)
# Problematic frame:
# C [ig4icd32.dll+0x2f9d0]
# If you would like to submit a bug report, please visit:
# http://java.sun.com/webapps/bugreport/crash.jsp
--------------- T H R E A D ---------------
Current thread (0x16f8cc00): JavaThread "AWT-EventQueue-0" [_thread_in_native, id=3936]
siginfo: ExceptionCode=0xc0000005, reading address 0x0a74c989
Registers:
EAX=0x0a74c985, EBX=0x00000000, ECX=0x373552d8, EDX=0x00000018
ESP=0x175df41c, EBP=0x175df458, ESI=0x00000018, EDI=0x000003fd
EIP=0x2705f9d0, EFLAGS=0x00210202
Top of Stack: (sp=0x175df41c)
0x175df41c: 00000018 0014d9e8 2705fa13 00000018
0x175df42c: 00000000 0014d9e8 13390a30 2705fb14
0x175df43c: 00000018 16f8cc00 13390a30 175eb075
0x175df44c: 00008892 00000018 2704f1c0 175df49c
0x175df45c: 0091a440 16f8ccec 175df4bc 00008892
0x175df46c: 00000018 2704f1c0 00000000 00000002
0x175df47c: 175df47c 00000000 175df4bc 13442ca8
0x175df48c: 00000000 13390a30 00000000 175df4ac
Instructions: (pc=0x2705f9d0)
0x2705f9c0: f7 8b 41 0c 8b 04 90 85 c0 74 10 eb 03 8d 49 00
0x2705f9d0: 39 70 04 74 0d 8b 00 85 c0 75 f5 5f 33 c0 5e c2
Stack: [0x17590000,0x175e0000), sp=0x175df41c, free space=317k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
j com.sun.opengl.impl.GLImpl.dispatch_glBindBufferARB0(IIJ)V+0
j com.sun.opengl.impl.GLImpl.glBindBufferARB(II)V+31
j org.xith3d.render.jsr231.ShapeAtomPeer.bindGeometryComponent(Ljavax/media/opengl/GL;Lorg/xith3d/render/RenderPeer;Lorg/xith3d/render/RenderOptions;Lorg/xith3d/scenegraph/GeomData;IIZ)V+114
j org.xith3d.render.jsr231.ShapeAtomPeer.setupBuffers(Lorg/xith3d/render/RenderPeer;Lorg/xith3d/render/RenderOptions;Ljavax/media/opengl/GL;Lorg/xith3d/scenegraph/GeometryArray;Z)V+25
j org.xith3d.render.jsr231.ShapeAtomPeer.drawGeometry(Lorg/xith3d/render/RenderPeer;Lorg/xith3d/render/RenderOptions;Ljavax/media/opengl/GL;Lorg/xith3d/scenegraph/GeometryArray;Z)I+323
j org.xith3d.render.jsr231.ShapeAtomPeer.render(Ljavax/media/opengl/GL;Lorg/xith3d/render/prerender/ShapeAtom;Lorg/xith3d/scenegraph/Appearance;Lorg/xith3d/scenegraph/Geometry;Lorg/xith3d/scenegraph/GeometryArray;ZZZZZZLorg/xith3d/render/RenderPeer;Lorg/xith3d/render/RenderOptions;Z)I+602
j org.xith3d.render.jsr231.ShapeAtomPeer.renderAtom(Lorg/xith3d/render/RenderPeer;Lorg/xith3d/render/RenderOptions;Lorg/xith3d/render/prerender/RenderAtom;JJLorg/xith3d/render/RenderPeer$RenderMode;J)I+749
J org.xith3d.render.RenderPeer.renderAtom(Lorg/xith3d/render/RenderOptions;Lorg/xith3d/render/prerender/RenderAtom;Lorg/xith3d/scenegraph/View;JJJLorg/xith3d/render/RenderPeer$RenderMode;)I
j org.xith3d.render.jsr231.RenderPeerImpl.drawBin(Ljavax/media/opengl/GL;Lorg/xith3d/render/RenderOptions;ZZLorg/xith3d/render/prerender/RenderBin;Lorg/xith3d/scenegraph/View;Lorg/openmali/spatial/bodies/Frustum;JIJJLorg/xith3d/render/RenderPeer$RenderMode;)I+81
j org.xith3d.render.jsr231.RenderPeerImpl.renderMain(Ljavax/media/opengl/GL;Lorg/xith3d/render/RenderOptions;ZZLorg/xith3d/scenegraph/View;Lorg/openmali/spatial/bodies/Frustum;Lorg/xith3d/render/RenderPass;Lorg/openmali/vecmath2/Matrix3f;JIJJLorg/xith3d/render/RenderPeer$RenderMode;)I+84
j org.xith3d.render.jsr231.RenderPeerImpl.renderRenderPass(Ljava/lang/Object;Ljava/util/List;Lorg/xith3d/render/RenderPass;IZLorg/xith3d/render/RenderPeer$RenderMode;Lorg/xith3d/scenegraph/View;ZJJJLorg/xith3d/picking/PickRequest;I)I+577
j org.xith3d.render.jsr231.RenderPeerImpl.render(Ljava/lang/Object;Lorg/xith3d/scenegraph/View;Lorg/xith3d/render/prerender/BackgroundCache;Ljava/util/List;ZJJJLorg/xith3d/picking/PickRequest;)Ljava/lang/Object;+215
j org.xith3d.render.jsr231.CanvasPeerImplBase.doRender(Lorg/xith3d/scenegraph/View;Lorg/xith3d/render/prerender/BackgroundCache;Ljava/util/List;ZJJJLorg/xith3d/picking/PickRequest;)Ljava/lang/Object;+21
j org.xith3d.render.jsr231.CanvasPeerImplAWT.display(Ljavax/media/opengl/GLAutoDrawable;)V+201
j com.sun.opengl.impl.GLDrawableHelper.display(Ljavax/media/opengl/GLAutoDrawable;)V+29
j javax.media.opengl.GLCanvas$DisplayAction.run()V+80
j com.sun.opengl.impl.GLDrawableHelper.invokeGL(Ljavax/media/opengl/GLDrawable;Ljavax/media/opengl/GLContext;Ljava/lang/Runnable;Ljava/lang/Runnable;)V+418
j javax.media.opengl.GLCanvas$DisplayOnEventDispatchThreadAction.run()V+35
j java.awt.event.InvocationEvent.dispatch()V+11
j java.awt.EventQueue.dispatchEvent(Ljava/awt/AWTEvent;)V+26
j java.awt.EventDispatchThread.pumpOneEventForFilters(I)Z+156
j java.awt.EventDispatchThread.pumpEventsForFilter(ILjava/awt/Conditional;Ljava/awt/EventFilter;)V+30
j java.awt.EventDispatchThread.pumpEventsForHierarchy(ILjava/awt/Conditional;Ljava/awt/Component;)V+11
j java.awt.EventDispatchThread.pumpEvents(ILjava/awt/Conditional;)V+4
j java.awt.EventDispatchThread.pumpEvents(Ljava/awt/Conditional;)V+3
j java.awt.EventDispatchThread.run()V+9
v ~StubRoutines::call_stub
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x1fbf5400 JavaThread "TimerQueue" daemon [_thread_blocked, id=2880]
0x1fddfc00 JavaThread "Xith3D render thread" [_thread_blocked, id=4084]
0x1fce4400 JavaThread "Thread-4" daemon [_thread_in_native, id=2104]
0x002a6800 JavaThread "DestroyJavaVM" [_thread_blocked, id=764]
=>0x16f8cc00 JavaThread "AWT-EventQueue-0" [_thread_in_native, id=3936]
0x16f3e000 JavaThread "AWT-Windows" daemon [_thread_in_native, id=3084]
0x16f3d400 JavaThread "AWT-Shutdown" [_thread_blocked, id=3260]
0x16f0f800 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=2312]
0x16b7c000 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=3824]
0x16b77400 JavaThread "CompilerThread0" daemon [_thread_blocked, id=3972]
0x16b76000 JavaThread "Attach Listener" daemon [_thread_blocked, id=4020]
0x16b75400 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=3876]
0x16b67400 JavaThread "Finalizer" daemon [_thread_blocked, id=2464]
0x16b63000 JavaThread "Reference Handler" daemon [_thread_blocked, id=2044]
Other Threads:
0x16b5e400 VMThread [id=2028]
0x16b86800 WatcherThread [id=2416]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
def new generation total 2944K, used 1891K [0x02990000, 0x02cc0000, 0x03d40000)
eden space 2624K, 72% used [0x02990000, 0x02b68e40, 0x02c20000)
from space 320K, 0% used [0x02c70000, 0x02c70000, 0x02cc0000)
to space 320K, 0% used [0x02c20000, 0x02c20000, 0x02c70000)
tenured generation total 38552K, used 31014K [0x03d40000, 0x062e6000, 0x12990000)
the space 38552K, 80% used [0x03d40000, 0x05b89a18, 0x05b89c00, 0x062e6000)
compacting perm gen total 17152K, used 17028K [0x12990000, 0x13a50000, 0x16990000)
the space 17152K, 99% used [0x12990000, 0x13a31370, 0x13a31400, 0x13a50000)
No shared spaces configured.
Dynamic libraries:
0x00400000 - 0x00423000 C:\fms\heli-x-windows\HELI-X\Java\jre1.6.0_03\bin\java.exe
0x7c900000 - 0x7c9b5000 C:\WINDOWS\system32\ntdll.dll
0x7c800000 - 0x7c900000 C:\WINDOWS\system32\kernel32.dll
0x77f40000 - 0x77feb000 C:\WINDOWS\system32\ADVAPI32.dll
0x77da0000 - 0x77e32000 C:\WINDOWS\system32\RPCRT4.dll
0x77f10000 - 0x77f21000 C:\WINDOWS\system32\Secur32.dll
0x7c340000 - 0x7c396000 C:\fms\heli-x-windows\HELI-X\Java\jre1.6.0_03\bin\msvcr71.dll
0x6d7c0000 - 0x6da0a000 C:\fms\heli-x-windows\HELI-X\Java\jre1.6.0_03\bin\client\jvm.dll
0x7e390000 - 0x7e421000 C:\WINDOWS\system32\USER32.dll
0x77e40000 - 0x77e89000 C:\WINDOWS\system32\GDI32.dll
0x76af0000 - 0x76b1e000 C:\WINDOWS\system32\WINMM.dll
0x76330000 - 0x7634d000 C:\WINDOWS\system32\IMM32.DLL
0x6d310000 - 0x6d318000 C:\fms\heli-x-windows\HELI-X\Java\jre1.6.0_03\bin\hpi.dll
0x76bb0000 - 0x76bbb000 C:\WINDOWS\system32\PSAPI.DLL
0x6d770000 - 0x6d77c000 C:\fms\heli-x-windows\HELI-X\Java\jre1.6.0_03\bin\verify.dll
0x6d3b0000 - 0x6d3cf000 C:\fms\heli-x-windows\HELI-X\Java\jre1.6.0_03\bin\java.dll
0x6d7b0000 - 0x6d7bf000 C:\fms\heli-x-windows\HELI-X\Java\jre1.6.0_03\bin\zip.dll
0x6d000000 - 0x6d1c3000 C:\fms\heli-x-windows\HELI-X\Java\jre1.6.0_03\bin\awt.dll
0x72f70000 - 0x72f96000 C:\WINDOWS\system32\WINSPOOL.DRV
0x77be0000 - 0x77c38000 C:\WINDOWS\system32\msvcrt.dll
0x774a0000 - 0x775dd000 C:\WINDOWS\system32\ole32.dll
0x746a0000 - 0x746ec000 C:\WINDOWS\system32\MSCTF.dll
0x75250000 - 0x7527e000 C:\WINDOWS\system32\msctfime.ime
0x7c9c0000 - 0x7d1e2000 C:\WINDOWS\system32\shell32.dll
0x77e90000 - 0x77f06000 C:\WINDOWS\system32\SHLWAPI.dll
0x77390000 - 0x77493000 C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.5512_x-ww_35d4ce83\comctl32.dll
0x5d4e0000 - 0x5d57a000 C:\WINDOWS\system32\comctl32.dll
0x6d2b0000 - 0x6d303000 C:\fms\heli-x-windows\HELI-X\Java\jre1.6.0_03\bin\fontmanager.dll
0x6d570000 - 0x6d583000 C:\fms\heli-x-windows\HELI-X\Java\jre1.6.0_03\bin\net.dll
0x71a30000 - 0x71a47000 C:\WINDOWS\system32\WS2_32.dll
0x71a20000 - 0x71a28000 C:\WINDOWS\system32\WS2HELP.dll
0x6d590000 - 0x6d599000 C:\fms\heli-x-windows\HELI-X\Java\jre1.6.0_03\bin\nio.dll
0x6d450000 - 0x6d474000 C:\fms\heli-x-windows\HELI-X\Java\jre1.6.0_03\bin\jpeg.dll
0x6d220000 - 0x6d243000 C:\fms\heli-x-windows\HELI-X\Java\jre1.6.0_03\bin\dcpr.dll
0x175e0000 - 0x1762d000 C:\fms\heli-x-windows\HELI-X\libs\jogl\windows-i586\jogl.dll
0x5f160000 - 0x5f22c000 C:\WINDOWS\system32\OPENGL32.dll
0x5f400000 - 0x5f421000 C:\WINDOWS\system32\GLU32.dll
0x736d0000 - 0x7371b000 C:\WINDOWS\system32\DDRAW.dll
0x73b30000 - 0x73b36000 C:\WINDOWS\system32\DCIMAN32.dll
0x17660000 - 0x1766b000 C:\fms\heli-x-windows\HELI-X\libs\joal\windows-i586\joal_native.dll
0x17670000 - 0x17675000 C:\fms\heli-x-windows\HELI-X\libs\gluegen\windows-i586\gluegen-rt.dll
0x17680000 - 0x178a5000 C:\fms\heli-x-windows\HELI-X\libs\joal\windows-i586\OpenAL32.dll
0x76f90000 - 0x7700f000 C:\WINDOWS\system32\CLBCATQ.DLL
0x77010000 - 0x770dd000 C:\WINDOWS\system32\COMRes.dll
0x770e0000 - 0x7716b000 C:\WINDOWS\system32\OLEAUT32.dll
0x77bd0000 - 0x77bd8000 C:\WINDOWS\system32\VERSION.dll
0x73e80000 - 0x73edc000 C:\WINDOWS\system32\dsound.dll
0x76bf0000 - 0x76c1e000 C:\WINDOWS\system32\WINTRUST.dll
0x77a40000 - 0x77ad6000 C:\WINDOWS\system32\CRYPT32.dll
0x77ae0000 - 0x77af2000 C:\WINDOWS\system32\MSASN1.dll
0x76c50000 - 0x76c78000 C:\WINDOWS\system32\IMAGEHLP.dll
0x72c90000 - 0x72c99000 C:\WINDOWS\system32\wdmaud.drv
0x72c80000 - 0x72c88000 C:\WINDOWS\system32\msacm32.drv
0x77bb0000 - 0x77bc5000 C:\WINDOWS\system32\MSACM32.dll
0x77ba0000 - 0x77ba7000 C:\WINDOWS\system32\midimap.dll
0x73e50000 - 0x73e54000 C:\WINDOWS\system32\KsUser.dll
0x209b0000 - 0x209c6000 C:\fms\heli-x-windows\HELI-X\libs\jinput\windows-i586\jinput-dx8.dll
0x6d320000 - 0x6d359000 C:\WINDOWS\system32\DINPUT8.dll
0x68db0000 - 0x68db9000 C:\WINDOWS\system32\HID.DLL
0x778e0000 - 0x779d7000 C:\WINDOWS\system32\SETUPAPI.DLL
0x20a40000 - 0x20a56000 C:\fms\heli-x-windows\HELI-X\libs\jinput\windows-i586\jinput-raw.dll
0x6d1f0000 - 0x6d21f000 C:\fms\heli-x-windows\HELI-X\Java\jre1.6.0_03\bin\cmm.dll
0x20bc0000 - 0x20e95000 C:\WINDOWS\system32\xpsp2res.dll
0x6d3e0000 - 0x6d3e6000 C:\fms\heli-x-windows\HELI-X\Java\jre1.6.0_03\bin\jawt.dll
0x171f0000 - 0x171f5000 C:\fms\heli-x-windows\HELI-X\libs\jogl\windows-i586\jogl_awt.dll
0x27030000 - 0x2727e000 C:\WINDOWS\system32\ig4icd32.dll
0x27310000 - 0x2748c000 C:\WINDOWS\system32\ig4dev32.dll
VM Arguments:
jvm_args: -Dsun.java2d.noddraw=true -Djava.library.path=./libs;./libs/gluegen/windows-i586;./libs/jinput/windows-i586;./libs/jogl/windows-i586;./libs/lwjgl/windows-i586;./libs/joal/windows-i586 -Xmx256m
java_command: ch.ntb.HeliX.application.Application
Launcher Type: SUN_STANDARD
Environment Variables:
PATH=C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program Files\Common Files\Roxio Shared\DLLShared\;C:\Program Files\Common Files\Roxio Shared\9.0\DLLShared\
USERNAME=Hugo.Bartels
OS=Windows_NT
PROCESSOR_IDENTIFIER=x86 Family 6 Model 15 Stepping 11, GenuineIntel
--------------- S Y S T E M ---------------
OS: Windows XP Build 2600 Service Pack 3
CPU:total 2 (2 cores per cpu, 1 threads per core) family 6 model 15 stepping 11, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3
Memory: 4k page, physical 1038632k(227432k free), swap 2499884k(1762148k free)
vm_info: Java HotSpot(TM) Client VM (1.6.0_03-b05) for windows-x86, built on Sep 24 2007 22:24:33 by "java_re" with unknown MS VC++:1310
Thanx!
Registers:
Other Threads:
Heap
Dynamic libraries:
VM Arguments:
OS=Windows_NT
