... in jme, you get it using
LegacyApplication.getRenderer().getCaps().toString()
This is, what HELI-X outputs in the "About window".
Kein Bild mit macOS Sequoia 15.2
Re: Kein Bild mit macOS Sequoia 15.2
This is the output I get:
[FrameBuffer, FrameBufferMRT, OpenGL20, OpenGL21, OpenGL30, OpenGL31, OpenGL32, OpenGL33, OpenGL40, OpenGL41, GLSL100, GLSL110, GLSL120, GLSL130, GLSL140, GLSL150, GLSL330, GLSL400, GLSL410, VertexTextureFetch, GeometryShader, TesselationShader, TextureArray, FloatTexture, FloatColorBufferRGB, FloatColorBufferRGBA, IntegerTexture, FloatColorBuffer, PackedFloatTexture, SharedExponentTexture, PackedFloatColorBuffer, NonPowerOfTwoTextures, VertexBufferArray, PackedDepthStencilBuffer, Srgb, FrameBufferBlit, TextureCompressionS3TC, TextureFilterAnisotropic, DepthTexture, IntegerIndexBuffer, SeamlessCubemap, CoreProfile, UnpackRowLength]
Winfried
public class TestApplication {
public static void main(String[] args) throws InterruptedException{
System.out.println("Creating application..");
LegacyApplication app = new LegacyApplication();
System.out.println("Starting application in LWJGL mode..");
app.start();
System.out.println("Waiting 5 seconds");
Thread.sleep(5000);
System.out.println(app.getRenderer().getCaps().toString());
System.out.println("Closing application..");
app.stop();
Winfried
app.start();
Thread.sleep(5000);
app.stop();
This looks as usual. That means that the driver of the graphcis adapter does not seem to cause the problem ...
Dear all,
Update?
Do you have an update on any progress made getting Heli-X to run on macOS 15.2?
Also-
Only Intel?
Is Heli-X on macOS 15.2 only a problem with Intel-based Macs?
M-series processors ok?
Is anyone successfully running Heli-X on macOS 15.2 on an Apple M-series Mac?
Fingers crossed that you can find an acceptable fix
Gareth
Update?
Also-
Only Intel?
Gareth
While I don't experience any obvious graphics issues (Sequoia 15.2, M1 Mac Mini), it is not really usable because the input randomly seems to get "laggy", meaning it's not picking but input changes from the controller/joystick immediately. I even noticed this during the initial sticks setup.
I'm currently using my JETI DS-16 connected via USB as a controller.
We're now on Sequoia 15.3 and my 2019 Intel-based iMac still isn't working with Heli-X.
I'm a little surprised how quiet this discussion is, surely someone knows something
Gareth
Gareth
hi guys,
I would like to now if this issue applies also on M CPUs or only on Intel.
Thanks for your feedback.
Marco
Marco
Good news, I figured out what was causing my input problems: When connected via USB, the JETI DS-16 connects as both a HID and an mass storage device (for transferring files to/from the integrated SD card). Spotlight was trying to index the contents of SD card and apparently that was eating up all the bandwidth of the not very performant USB connection to the transmitter.
So I can state: No graphics problems and no input problems on M1 Mac Mini with Sequoia 15.3.
Es ist ja jetzt schon etwas her gibt es schon eine Lösung?
Hallo ich habe ein Problem mit Heli-X 10 auf meinem MacBook Pro M2 Pro mit macOS Sequoia 15.3.2, nach der Abfrage Mouse Speed beendet sich das Programm.
Auf meinem MacMini M4 funktioniert es ohne Probleme.
Auf meinem Notebook habe ich mehrere Java Versionen, ich habe aber die JAVA_HOME auf die Version 11.0.26 gesetzt.
Wenn ich das Heli-X über das Terminal starte dann komme ich etwas weiter, dann funktioniert die Maus nicht.
Hat vielleicht jemand eine Idee ?
