Hi guys, i having a problem with disconnecting my vbar evo controller when on wifi. Let me just say wright from the start that i don't thing it it an issue with the sim. From the beginning everything has been flawless until recently. It's either my laptop Dell XPS 15 (2018) or my router. So my question is what setting i should check. Router is netgear but bit older so no update avaible for some time. After while the computer completely disconnects from the network and reconnects or have to run troubleshoot. Is it important in which order are appliances connected to the network? Opening the sim and them connecting the vbar control?
Thank you for any help. R
Mikado Vbar evo keeps disconnecting from wifi
Re: Mikado Vbar evo keeps disconnecting from wifi
In V10, restrict the frame rate to 200 or less when using the VBAR via WLAN
