Hello everyony.
Anybody able to use FMS PIC controller with Linux version of Helix?
Is any of the developers interested in introducing support for this kind of interface? I can share some code if You are willing to implement it
FMS PIC controller under linux
Re: FMS PIC controller under linux
HELI-X requires an USB interface at the moment.
HELI-X uses the library jinput. Perhaps you can implement an wrapper ... ?
i have a usb / rs233 convertes so my PIC controller is connected via USB to my linux box but i guess there has to be a code to understand the data format that PIC transmitter uses.
- Grant_Edwards
If you're still interested in using an FMS PIC cable, I've made available a Linux driver that allows you to use one type of FMS PIC cable with Heli-X: viewtopic.php?f=9&t=1024polrus wrote:i have a usb / rs233 convertes so my PIC controller is connected via USB to my linux box but i guess there has to be a code to understand the data format that PIC transmitter uses.
I'd be happy to modify it to also recognize the other type of FMS PIC cable (the 19200 baud protocol) if somebody wanted to loan me one for a few days...
- Grant_Edwards
Just to avoid future confusion, Heli-X (at least since 4.1) does not require a USB interface. It uses the normal Linux event/joystick device API, so anything that works with that (USB HID, serial-port, gameport, parallel port, PWM audio-card-input, etc.) will work with Heli-X on Linux.Michael wrote:HELI-X requires an USB interface at the moment.
The actual electrical interface between the computer and the joystic doesn't matter.
