Hi, I just discovered Heli-X and downloaded the demo version to see if it was worth buying the full version. It is every bit as good if not better than my Phoenix simulator. But the only problem I have which is a big one and my prevent me from buying the full version is that while I'm on the sim, whether I'm flying or hovering or on the ground, the program will reload and when I press ok after it reloads, the helicopter I was using disappears and I have reselect it. This happens constantly, So I was wondering if there is any explanation to this issue?
Thank you
Mike
USA
