Lumenier QAV250
Re: Lumenier QAV250
I am looking for a good 250 flight model too, if someone have one it would be great!
Re: Lumenier QAV250
Same here looking for a good 250h for fpv practice.
Re: Lumenier QAV250
Maybe check for new helis in the update menu?...
The H.250 quad is already there for some time...
As seen here: http://youtu.be/hkJ6db3CgzI
Re: Lumenier QAV250
Yep but the h250, flight model is far from reality I flew it a few times and it is not good at all
Re: Lumenier QAV250
Regarding the flight characteristics there seem different views and ofc different setups. Cell count, AUW, prop sizes, motors and ofc FC and ESC settings can make for a broad spectrum.
In the sim you can tune the flight characteristics in the XML file of the model to your liking. If that doesn't help you may get assistance online or post required changes here. Specific answer is difficult based on good or not good.
Re: Lumenier QAV250
You are right, I am trying to simulate a zmr 250, 2208 cobra motors, with 6x4.5 props and 4s 2200 battery, with an acro naze 32, total weight it is around 630 grams. I dont know how can I set up the XML, If you could help me to do so It would be great! Thanks
Re: Lumenier QAV250
Locate the file here in yout Heli-X directory: ..\resources\models\helicopter\H250\H250.xml
Flight behavior is not defined there by component specs but directly how the heli should fly using them. The individual parameters begin with the parameter name in <> and end with the name in </>, the actual value in between. For example:
All parameters are described in the User manual (http://www.heli-x.info/help/UsersManualV6.pdf) section 4.1.3.
You could also describe a desired effect here (somethin like "when moving roll stick fully to either side, the quad should rotate about twice as quick") and hope somebody experienced can translate that somehow into parameters. I haven't much experience with flight parameters so probably won't be me.
<YawExpo>0</YawExpo>
Re: Lumenier QAV250
Thanks for your answer, I will wait until someone who knows how to make a model actually make a good 250 racer as I dont see myself able to do one !
Re: Lumenier QAV250
I think there is nothing wrong with theh250 model.
Sure, its somewhat underpowered to what you fly today, more a 3S 5030 setup from 2013, but still - its perfectly fine to practise motion sequences.
Besides, additional power would be of no real use, because available maps are to small.
Here is some h250 FPV footage from a few days ago:
https://www.youtube.com/watch?v=kaayQHlr24o
