Issues with Heli-X launching in OSx 10.8.2
Posted: 06 Feb 2013 20:42
by jbudowski
Application will no longer launch. Shows up on dock then disappears. Console shows com.apple.launchd.peruser.501: ([0x0-0x4f04f].net.heli-x.heli-x[642]) Exited with code: 1. Using Java 7 update 13. Thanks.
Re: Issues with Heli-X launching in OSx 10.8.2
Posted: 06 Feb 2013 22:48
Please download the latest Java 6 from Apple's website.
http://support.apple.com/kb/DL1573
Posted: 11 Feb 2013 13:33
by jbudowski
That package will only load with OSx 10.6. I'm running 10.8.2. Thanks.
Posted: 11 Feb 2013 16:54
Posted: 13 Feb 2013 14:27
by jbudowski
Successfully installed the specified version of Java but, unfortunately, same result, same error.
Posted: 19 Feb 2013 23:26
Then you can try to remove Java 7.
michael
Posted: 05 Mar 2013 01:21
by ssalmenkivi
I have a similar problem with OSx 10.8.2 - I just downloaded Heli-X 4.2 but the dmg file doesn't start.
I have Java 1.6.0_41.
Posted: 05 Mar 2013 21:51
what exactly is going on? Could you unzip the file? Could you open the dmg file? Could you install the app?
michael
Posted: 06 Mar 2013 16:42
by jbudowski
So I finally figured out the issue. My antivirus software was blocking some of the files. Figuring that out was only half the problem! Then I had to figure out how to make it stop (which should have been much easier than it turned out to be). Anyway, I'm in good shape now. Thanks.
