No controller in 1.0 - still works in 0.9
Posted: 26 Nov 2008 12:05
by s_illes79
My Spektrum DXi6 is working perfectly in Heli-x 0.9, no problem there
but not in 1.0.
There was a popup message during first startup that a controllas has been found and needs to be configured, I did all the steps, however the axis indicator were not moving at all.
It looks like it has found the controller but not able to use it. Log:
Set new path for the resources: /home/illes/tmp/HELI-X/resources/
Set new path for the user files: /home/illes/tmp/HELI-X/files/
Using openGLLayer JOGL_AWT
Found 11 display modes
Failed to open device (/dev/input/event8): Failed to open device /dev/input/event8 (13)
Failed to open device (/dev/input/event6): Failed to open device /dev/input/event6 (13)
Linux plugin claims to have found 4 controllers
Controller found: Name: ? PPM (? PPM )
Using Stick ? PPM
Digital component found:Trigger
Digital component found:Thumb
Digital component found:Thumb 2
Analog component found:x
Analog component found:y
Analog component found:z
Analog component found:rx
Analog component found:ry
Controller configuration file found: /home/illes/tmp/HELI-X/files/controller/PPM.xml
Controller configuration file /home/illes/tmp/HELI-X/files/controller/PPM.xml read
dmesg:
input: ? PPM as /devices/pci0000:00/0000:00:1d.7/usb2/2-3/2-3.1/2-3.1:1.0/input/input4
input,hidraw0: USB HID v1.00 Joystick [? PPM ] on usb-0000:00:1d.7-3.1
Thanks
Re: No controller in 1.0 - still works in 0.9
Posted: 26 Nov 2008 12:28
it looks as if you do not have enough permissions. Try this as root:
chmod o+rwx /dev/input/e*
HTH,
Posted: 26 Nov 2008 20:28
by s_illes79
Hi Michael,
The trick worked,
Thanks
