Distance to "cage"
Posted: 27 Aug 2013 21:42
by ukarlsson
Thanks for providing this software and support forum. I'm trying to train some manouvers and not float away to much in any direction, thus I'm playing around with the Training-Cage mode. It's pretty good, but the cage is way too close to the camera, it's like flying with my 500-size heli 3 m away from myself trying to do flips! Can I somehow move the cage farther away from the camera or use some other feature to practice staying in the same point while cranking away on the sticks?
Kind regards,
Re: Distance to "cage"
Posted: 27 Aug 2013 22:29
by JS1
The easiest way probably would be to zoom out in the view menu, if that's what you are looking for.
Posted: 29 Nov 2013 06:59
by helicopter
JS1 wrote:The easiest way probably would be to zoom out in the view menu, if that's what you are looking for.
i think it worth to try...
Posted: 29 Nov 2013 17:18
Or you can edit the xml file of the airport and change the helixopter's start position ...
In V5 this cen be done with the menu ...
