Phantom 2 controller
Posted: 05 Apr 2014 18:34
by paul2143
I have just downloaded the demo and am trying to set it up using the phantom 2 quadcopter controller. Does this controller work in the demo as I cant seem to get it to connect or do anything. Hence Im not sure if i purchase the complete version will it work?
I can't find any instructions how to connect the controller I have connected the usb lead that came with the controller but from there I cant find what to do?
Im using a Mac OSX version10.9.2 any help would be appreciated thank you
Re: Phantom 2 controller
Posted: 05 Apr 2014 18:41
The Controller of the Phantom can not be used as Joystick, neither on Windows nor on Mac.
Posted: 07 Apr 2014 09:04
by JS1
Just get a cheap USB controller instead. Could be better anyway (and cheaper longterm) since I am not sure how easy it is to replace the original DJI Phantom transmitter. If you train a lot in the simulator any transmitter would show signs of wear soon, usually sticks and switches first.
Posted: 14 Nov 2014 20:22
by happydays
With the new DJI remote controller, there is an output for use with a simulator. Does anyone know which cable to use with this?
Posted: 19 Nov 2014 20:15
by Hardattack
I would like to know also. Just bought a phantom and would like to practice on simulator first
Posted: 28 Nov 2014 19:57
by happydays
Got a cable and hoped it up, but it isn't recognised. I can't get the mac to recognise it. I can't get the calibration to start at all.
Posted: 07 Dec 2014 18:59
by banshee
I have the same problem. I have the upgraded DJI Phantom 2 controller with trainer jack in back of remote control. I also have the Hobby King adapter box that has a 3 conductor plug that fits into the Phantom trainer jack with the the other end (that is a 3 conductor plug) plugged into the lobby King adapter. On the Hobby King adapter there is a mini usb receptacle that I have used a standard USB cable to plug into my mac book pro. As a result there is a green LED that is lit up in the Hobby King adapter. the Phantom controller is connected tot he HK adapter via the 3 conduct plug. On the HK adapter there are one 3 position switch (SW1) and one 4 position switch SW2). SW 2 positions are labeled XTR, RealFlight G, AEROFLY, PHOENIXRC. SW1 is labeled WIRE, WIRELESS, SIM BOX.
I would be most appreciate for any info on how to get this configuration working with Heli-X. Extra points for the same answer using the TARANIS controller on the Mac.
Thanks,
Banshee
