OS X High Sierra not running 6.1
Posted: 03 Nov 2017 02:37
by aehaas
I have OSX High Sierra and cannot run the program vr 6.1 Can this be made to run the currently installed JAVA?
aehaas
Re: OS X High Sierra not running 6.1
Posted: 04 Nov 2017 18:44
You need the java which is linked in the download section on the web site.
Posted: 05 Nov 2017 17:15
by aehaas
The latest version of MacOS High Sierra will not allow the older version of JAVA to be installed. Just the same it is more secure to use the newer version. Why not update the Heli-X program to accept the new JAVA versions?
aehaas
Posted: 12 Nov 2017 23:36
by krm97
I have the same issue with the latest OS X High Sierra update just released several days ago. When I try to boot up the program, I get the message " To use the java command-line tool you need to install a JDK" When I install the Java Development Kit, and start the Help-X program, I get the same message. I would greatly appreciate it if someone can provide a solution.
Ken
Posted: 13 Nov 2017 11:28
we are working onthis issue and try to include it in version 7. I'll come back to you for betat testing
Posted: 19 Nov 2017 21:31
V7 beta is ready for testing. There also the high sierra issue should be solved. Those who want to test, please send an email to info(at) heli-x.net
