JAVA error
Posted: 08 Jun 2009 11:07
by poxley100
I'm able to lauch heli-x.2.0 using ./runHELI-X.sh but when I try to select a helicopter the following java error occurs.
Linux 2.6.24-23-generic #1 SMP Mon Jan 26 00:13:11 UTC 2009 i686 GNU/Linux
java -> jre1.6.0_13
more runHELI-X-Server.sh
JAVAPATH=~/java/bin/
Exception occurred during event dispatching:
java.lang.NoClassDefFoundError: Jama/Matrix
at a.a.a.h.a.a(Unknown Source)
at a.a.a.i.e.E(Unknown Source)
at a.a.a.m.e.a(Unknown Source)
at a.a.a.d.a.h.actionPerformed(Unknown Source)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.Dialog$1.run(Unknown Source)
at java.awt.Dialog$3.run(Unknown Source)
at java.awt.Dialog.show(Unknown Source)
at java.awt.Component.show(Unknown Source)
at java.awt.Component.setVisible(Unknown Source)
at java.awt.Window.setVisible(Unknown Source)
at java.awt.Dialog.setVisible(Unknown Source)
at a.a.a.d.a.h.c(Unknown Source)
at a.a.a.d.a.h.<init>(Unknown Source)
at a.a.a.m.j.actionPerformed(Unknown Source)
at java.awt.MenuItem.processActionEvent(Unknown Source)
at java.awt.MenuItem.processEvent(Unknown Source)
at java.awt.MenuComponent.dispatchEventImpl(Unknown Source)
at java.awt.MenuComponent.dispatchEvent(Unknown Source)
Caused by: java.lang.ClassNotFoundException: Jama.Matrix
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
... 48 more
Re: JAVA error
Posted: 08 Jun 2009 11:22
I see this: java.lang.NoClassDefFoundError: Jama/Matrix
This belongs to a library which is used in version 1.1 but not in version 2.0 anymore. It koos as if you have a version mix. Please delete the old version and make a complete fresh installation. If you are an registered user, you'll get the update soon.
Re: JAVA error
Posted: 08 Jun 2009 11:26
by poxley100
Found a solution:
I compared heli-x.1.0 and helix.2.0 and found the missing class file jama:
To resolve the issue I copied the jama directory from version 1.0 to version 2.0 like so:
cd ~/HELI-X.2.0/libs/
cp -r ~/HELI-X.1.0/libs/jama ./
Then updates the startup script to include the classpath path.
edit runHELI-X.sh and add path
CP="$CP:$JARPATH/jama/Jama-1.0.2.jar"
The helicopter selection now works.
Peter
Re: JAVA error
Posted: 08 Jun 2009 11:29
Sure, but still strange, since this library should not be necessary.
Re: JAVA error
Posted: 08 Jun 2009 11:52
by poxley100
I extracted heli-x.2.0 into a new directory so there shouldn't be any files shared files with the old version.
I also noticed that when I try to select Utilities ActiveHeliport1_5 the following error appears and the utility fails to load.
java.lang.NullPointerException
at a.a.a.g.j.a(Unknown Source)
at a.a.a.i.e.a(Unknown Source)
at a.a.a.d.a.c.actionPerformed(Unknown Source)
at a.a.a.d.a.c.<init>(Unknown Source)
at java.awt.MenuItemException occurred during event dispatching:
Re: JAVA error
Posted: 08 Jun 2009 18:14
Thanks. But there is no need to select an ActiveHeliport as utility. They are automatically loaded in the cargo training.
Re: JAVA error
Posted: 08 Jun 2009 18:47
by poxley100
All my problems could be linked to the file HELIX.jar. To enable all features I copied this from version 1.0.
Could you forward me a new version for 2.0. My account is poxley.
Many thanks,
Peter
Re: JAVA error
Posted: 08 Jun 2009 21:20
by Chewy
Hello Peter,
poxley100 wrote:All my problems could be linked to the file HELIX.jar. To enable all features I copied this from version 1.0.
yes, that seems to be the problem, Michael is compiling the new files now, you will get yours be email (may be tonight, may be tomorrow)
