Camera configuration
Posted: 11 Jan 2025 16:42
by Murinos
Good afternoon!
I have troubles configuring camera.
I want it to be soft (model mofing on a screen and not tied to the center, to feel the movement) and to have zoom. But with the configuration I have the plane just flies away from the screen. Please take a look at the screenshots I attached. The "model on the screen" parameter is at "center". If i make it high or higher - it gets even worse, i see only ground. Would appreciate help with configuring it.Thanks!
Re: Camera configuration
Posted: 11 Jan 2025 16:57
Let's go step by step.
First: Make sure that you dot select "Freeze View" in the View Menu
Now the camera should follow the model
Next reduce "Maximal Angular veocity
And increase the time constant
Posted: 11 Jan 2025 18:46
by Murinos
Hi Michael,
Thanks for your reply.
I tried to do i, but still have problems. I made a video to show it, please check it. I've launched the program several times, to be sure the new config have applied, so there are several black periods between the sim launch.
https://youtu.be/5iJIX_mF4as
Posted: 11 Jan 2025 18:53
... turn the auto zoom off
... and set the inner area smaller
Posted: 11 Jan 2025 19:13
by Murinos
Posted: 11 Jan 2025 22:22
... so it works as expected ...
Great!
Posted: 12 Jan 2025 12:52
by Murinos
But I wanted to have both soft camera and zoom, as stated in my first post. And If i enable auto zoom, plane just flies away from the screen, or the camera tilts to the ground after plane reaching some distance. :(
Posted: 12 Jan 2025 19:01
by Murinos
I did some testing, it has nothing to do with soft camera. It's auto zoom + model on the screen feature what's causing problems. To me it looks like a bug...
https://youtu.be/ApzLIfijwaQ
UPD: I've reinstalled Heli-X - same problem...
