controller not smooth on linux
Posted: 06 Aug 2009 12:16
by fdtrex
I am currently evaluating 2.0 before buying. I have Esky 4-channel controller.
First I installed heli-x 2.0 on Windows and I have to say that I am quite satisfied with it, although it seems more difficult to me to pilot the simulator than a real helicopter.
Using exact same hardware (PC+controller) (in dual boot), I installed the same heli-x 2.0 package under linux (ubuntu 8.04).
The software starts correctly, controller is recognized and I configured it (using the wizard), I think, the same way as on Windows.
It works, I can control my heli, however it is not smooth at all: controlling the left/right for example the heli reacts only when I reach 75% (left/right) on the controller, which makes impossible any stable flight.
To be honest, I didn't look into all possible controller configuration settings as I assumed that the software would behave in the same way on linux/windows.
Would you have any tip to share to improve the linux experience and make it look like the Windows one?
Thanks in advance,
fdtrex
Re: controller not smooth on linux
Posted: 06 Aug 2009 14:33
Hello fdtrex,
to get the full resolution of your controller, please calibrate the controller on each OS, i.e. also on Linux. After the calibration wizard have a look at the 4 color bars. Do they move smoothly when you move the sticks?
Posted: 06 Aug 2009 15:47
by fdtrex
Hello Michael,
Thanks for helping me.
I just did some further investigations:
I have done the controller configuration again, and even there (in the config wizard) I see low resolution around stick center on the way forward (from center to outside). The way back (from outside to center) seems to be better.
Then I tried to pilot a bit.
It looks like on each of the 4 axis, one direction has low resolution while the other one is better.
As I said, it works fine on Windows, so the controller hardware is ok. Is there a way to troubleshoot at the driver level, for example to see the raw value returned for each stick movement?
Thanks,
fdtrex
Posted: 06 Aug 2009 16:46
Try to calibrate the controller with a joystick tool from linux (system settings).
Posted: 11 Aug 2009 15:41
by RainerS
Hello fdtrex,
I had the same problems as you. I changed the maximum values of each chanel in my remotcontrol (FC18) to
60%. Now it looks well.
regards
Rainer
Posted: 21 Aug 2009 18:46
by fdtrex
ok I have investigated this issue. Although I can not explain it really, it seems to be a permission problem.
Initially I have:
root@pc:/dev/input# ls -al
total 0
drwxr-xr-x 4 root root 300 Aug 21 19:30 .
drwxr-xr-x 12 root root 14420 Aug 21 19:31 ..
drwxr-xr-x 2 root root 80 Aug 21 19:30 by-id
drwxr-xr-x 2 root root 160 Aug 21 19:30 by-path
crw-rw---- 1 root root 13, 64 Aug 21 19:30 event0
crw-rw---- 1 root root 13, 65 Aug 21 19:30 event1
crw-rw---- 1 root root 13, 66 Aug 21 19:30 event2
crw-rw---- 1 root root 13, 67 Aug 21 19:30 event3
crw-rw---- 1 root root 13, 68 Aug 21 19:30 event4
crw-rw---- 1 root root 13, 69 Aug 21 19:30 event5
crw-rw---- 1 root root 13, 70 Aug 21 19:30 event6
crw-rw---- 1 root plugdev 13, 0 Aug 21 19:30 js0
crw-rw---- 1 root root 13, 63 Aug 21 2009 mice
crw-rw---- 1 root root 13, 32 Aug 21 2009 mouse0
crw-rw---- 1 root root 13, 33 Aug 21 19:30 mouse1
root@pc:/dev/input#
I start heli-x (not as root!) and I have the problem mentionned above.
Then I stop heli-x, and change the permissions:
root@pc:/dev/input# chmod a+rxw e*
total 0
crwxrwxrwx 1 root root 13, 64 Aug 21 19:30 event0
crwxrwxrwx 1 root root 13, 65 Aug 21 19:30 event1
crwxrwxrwx 1 root root 13, 66 Aug 21 19:30 event2
crwxrwxrwx 1 root root 13, 67 Aug 21 19:30 event3
crwxrwxrwx 1 root root 13, 68 Aug 21 19:30 event4
crwxrwxrwx 1 root root 13, 69 Aug 21 19:30 event5
crwxrwxrwx 1 root root 13, 70 Aug 21 19:30 event6
root@pc:/dev/input#
I restart heli-x (still not as root!), I recalibrate the controller and now it works fine. I tried it 2 times by rebooting the computer.
With permissions issues, I would expect to have no command at all, not the type of problem I reported.
Michael, do you see any explanation for that?
Thanks,
helibel.
Posted: 22 Aug 2009 16:28
Hi helibel,
really strange. Is your problem now solved for ever, or do you have to start and restart HELI-X every time? Please hava a look into the console window. Is there anything strange visible?
Thanks.
Posted: 23 Aug 2009 08:07
by fdtrex
Hi Michael,
I have to do it every time I reboot the computer. Not a big deal; I don't think I can permanently change the permissions on those entries as they are dynamic.
helibel
Posted: 24 Aug 2009 10:51
by RainerS
If you use Ubuntu 9.04 you have to build a file in
... lib/udev/rules.d/50-udev-default.rules
there must be a rule like
# USB devices (usbfs replacement)
SUBSYSTEM=="usb", ENV{DEVTYPE}=="usb_device", MODE="0666"
SUBSYSTEM=="usb_device", MODE="0666"
Rainer
