Heli wird nicht geladen
Posted: 22 Nov 2009 11:14
by mh75
Hallo Gemeinde,
nun hab ich das aktuelle 9.10 er ubuntu, heli-x installiert, da es 9.04 bei mir nicht lief (kein Joystick)
Diesmal hats geklappt. Allerdings nur bis zur Auswahl des Helis.
Hoffe, dass ich Java richtig installiert hab!
Die Konsole hat folgendes ausgespuckt!
Couldn't find tag "Resolution" in file "/home/m../Downloads/helix/HELI-X/files/Application/ViewSettings.xml"
Exception occurred during event dispatching:
java.lang.NoClassDefFoundError: Jama/Matrix
	at a.a.a.a.a.<init>(Unknown Source)
	at a.a.a.a.a.q.<init>(Unknown Source)
	at a.a.a.g.a.a(Unknown Source)
	at a.a.a.h.e.E(Unknown Source)
	at a.a.a.m.e.a(Unknown Source)
	at a.a.a.c.a.h.actionPerformed(Unknown Source)
	at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2012)
	at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2335)
	at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:404)
	at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259)
	at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:253)
	at java.awt.Component.processMouseEvent(Component.java:6108)
	at javax.swing.JComponent.processMouseEvent(JComponent.java:3267)
	at java.awt.Component.processEvent(Component.java:5873)
	at java.awt.Container.processEvent(Container.java:2105)
	at java.awt.Component.dispatchEventImpl(Component.java:4469)
	at java.awt.Container.dispatchEventImpl(Container.java:2163)
	at java.awt.Component.dispatchEvent(Component.java:4295)
	at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4461)
	at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4125)
	at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4055)
	at java.awt.Container.dispatchEventImpl(Container.java:2149)
	at java.awt.Window.dispatchEventImpl(Window.java:2478)
	at java.awt.EventQueue.dispatchEvent(EventQueue.java:604)
	at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:194)
	at java.awt.Dialog$1.run(Dialog.java:1072)
	at java.awt.Dialog$3.run(Dialog.java:1126)
	at java.awt.Dialog.show(Dialog.java:1124)
	at java.awt.Component.show(Component.java:1464)
	at java.awt.Component.setVisible(Component.java:1416)
	at java.awt.Window.setVisible(Window.java:842)
	at java.awt.Dialog.setVisible(Dialog.java:1011)
	at a.a.a.c.a.h.c(Unknown Source)
	at a.a.a.c.a.h.<init>(Unknown Source)
	at a.a.a.m.j.actionPerformed(Unknown Source)
	at java.awt.MenuItem.processActionEvent(MenuItem.java:644)
	at java.awt.MenuItem.processEvent(MenuItem.java:603)
	at java.awt.MenuComponent.dispatchEventImpl(MenuComponent.java:312)
	at java.awt.MenuComponent.dispatchEvent(MenuComponent.java:300)
	at java.awt.EventQueue.dispatchEvent(EventQueue.java:607)
Caused by: java.lang.ClassNotFoundException: Jama.Matrix
	at java.net.URLClassLoader$1.run(URLClassLoader.java:217)
	at java.net.URLClassLoader.findClass(URLClassLoader.java:205)
	at java.lang.ClassLoader.loadClass(ClassLoader.java:319)
	at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:294)
	at java.lang.ClassLoader.loadClass(ClassLoader.java:264)
	at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:332)
	... 50 more
Also Heli-x startet ganz normal, sogar den Joystick kann ich diesmal konfigurieren.
Flugplatzbild ist da, die Heliauswahl ist auch da, aber wenn ich auf ok gehe, um einen Heli auszuwählen, dann geht nix mehr!
was fehlt da noch??
Gruß' mh75
Re: Heli wird nicht geladen
Posted: 22 Nov 2009 12:14
Du hast einen Versionskonflikt. Du arbeitest mit einem Gemisch aus Version 2.0 und einer älteren. Mach mal das Sytsem sauber,lade die Version 2.0 herunter und bring die Demoversion zum laufen. Dann kannst Du Deine Version 2.0 drüber installieren.
Posted: 22 Nov 2009 14:29
by mh75
Hi Michael,
was meinst du genau?
Ich hab das neuste heli -x runtergeladen und (da ubuntu Neuinstallation) auch erst einmal installiert!
oder meinst du java?
gruß Markus
Posted: 22 Nov 2009 15:22
Ich sehe bei Dir
Aber diese Klasse ist schon lange Zeit nicht mehr in HEL-X drin.
Posted: 22 Nov 2009 15:44
by mh75
soo jetzt läufts.
Hat wohl mit der eingefügten jar. Datei zusammen gehangen.
habs nochmal neu entpackt und registriert und jetzt gehts.
An java hab ich nix geändert.
Danke Gruß Markus
