PPJoy for Linux
Posted: 09 Feb 2010 22:45
to connect your transmitter with your sondcard on Linux try this:
http://rc.zexos.org/txppm.html
Um den Sender über die Soundkarte mit dem Rechner zu verbinden, gibt es jetzt das:
Thanks to Tomáš 'ZeXx86' Jędrzejek
Re: PPJoy for Linux
Posted: 23 Mar 2010 07:12
by desmogod
Has anyone managed to get this working?
Having huge issues in Ubuntu 9.10
Re: PPJoy for Linux
Posted: 25 Mar 2010 17:38
by ZeXx86
desmogod wrote:Has anyone managed to get this working?
You should read README first, you have to install one required library - PortAudio + PortAudio developer version (contain headers needed for compilation) and linux-headers (it is probably installed by default) for kernel module.
Then there shoul'nt be any problem with it.
Remember, you have to own cable for connection between your transmitter and sound card (input - line in or mic in).
Check README for more info..
Thanks
Re: PPJoy for Linux
Posted: 11 Jul 2010 19:49
by ZeXx86
New version 0.0.4 is available now !
It implements CCPM 120° support which is mostly used in helicopter transmitters.
From now, almost all transmitters should work correctly with this software.
Download from
HERE
Re: PPJoy for Linux
Posted: 22 Jul 2010 10:40
by ZeXx86
New version 0.0.5 is here and brings full support for Spektrum transmitters (DX6i, DX7, etc).
For correct function use value 2 as second parameter.
