Inverted landing and better rotor colision
Posted: 17 Oct 2010 13:24
Hello
I want to suggest to add support in landing with inverted rotor and/or better collision with ground and main rotor.
It is not true, that rotor is damaged right after ground contact.
When you are experienced pilot it is not a problem to touch ground with blades.
There should be something like a smoke when you smoothly contact ground with blades or when you are touching with head stopper it should be almost without any damage.
