Heli-X and controller Mode
Posted: 15 Oct 2008 12:37
by Mehari
Can someone tell me whether Heli-X is compatible with both Mode 1 and Mode 2 transmitters?
I have a Mode 1 Spektrum DX7 transmitter connected to an iMac running OS10.5.2 via a Dynam SimulatorLine USB cable. The transmitter appears to communicate with Heli-X okay but after the controller configuration process is complete the mix of pitch, roll and nick is not what would be expected for Mode 1. I cannot find a way to set up either the transmitter or the configuration process to achieve the correct combination of servo actions for Mode 1.
Any suggestions? Thanks.
Re: Heli-X and controller Mode
Posted: 15 Oct 2008 12:43
yes, HELI-X is compatible with any flying mode you can imagine. The problems you describe seem to come from mixers which are active in your controller. You should switch of any mixers, or use a normal plane program or something similar.
Posted: 15 Oct 2008 23:27
by Mehari
I had the swash mix set to '3 servos/120 degrees'. I tried the other three combinations and found that '1 servo norm' is the only one that works. After a couple of servo reversals to get proper control I am now flying.
Many thanks for your help. Congratulations on a great sim.
Posted: 17 Oct 2008 17:05
by Joerg
Hm... 120° should be suboptimal. The most authentic control should be at 90° swash, 3 servos. However, I have no idea what "1 servo norm" does...
