Mikado Vbar evo keeps disconnecting from wifi
Posted: 30 Mar 2025 20:23
by Radek
Hi guys, i having a problem with disconnecting my vbar evo controller when on wifi. Let me just say wright from the start that i don't thing it it an issue with the sim. From the beginning everything has been flawless until recently. It's either my laptop Dell XPS 15 (2018) or my router. So my question is what setting i should check. Router is netgear but bit older so no update avaible for some time. After while the computer completely disconnects from the network and reconnects or have to run troubleshoot. Is it important in which order are appliances connected to the network? Opening the sim and them connecting the vbar control?
Thank you for any help. R
Re: Mikado Vbar evo keeps disconnecting from wifi
Posted: 30 Mar 2025 20:29
by admin
In V10, restrict the frame rate to 200 or less when using the VBAR via WLAN
Posted: 30 Mar 2025 21:00
by Radek
admin wrote: 30 Mar 2025 20:29 In V10, restrict the frame rate to 200 or less when using the VBAR via WLAN
Will try. Thank you for the tip.
